Old 03-20-2012, 12:32 PM   #11
Run to Rund
Liked 54 Times in 27 Posts
Default Re: Winch recomendations
Originally Posted by tj310 View Post
I have a Superwinch 2000 lb it pulls the 3000# car no problem. I double up the cable for the 4200# wagon kinda slow but it gets the job done.---Trevor
That is my thinking also. If the car rolls easily, winch it into the trailer directly. Use a snatch block if the car has a problem. It is also good if someone follows and keeps a 4x4 block close to a rear wheel so it won't roll back if the cable snaps or the winch fails. A coat on the cable will prevent it from whipping around if it breaks.
