#21 |
Interesting stuff here. I also am using the plastic pump and although I was leery at first, the thing works like a charm. I am concerned about vapors building up in the drum as the weather gets hotter. I have been going out and opening the cap on the drum to release the pressure on a regular basis.
I keep the pump hanging an only put it in the drum when I need fuel. Am I still OK here? Thoughts? |
#22 |
Liked 544 Times in 213 Posts
Say a prayer for me......
I cut the tops off metal drums with a plasma cutter on a regular basis. Been doing this for years. Most of the drums contained waste oil and other fluids....anti freeze, water. I use them to put crushed oil filters in and than put the drums in a metal scrap dumpster. I always remove the bungs before I cut the tops and check what was in them before firing up the plasma torch..... A few pounds of pressure in an open tank is not going to blow up unless you add a spark.... Gasoline is dangerous as a vapor for sure and needs to be treated with some respect.... If you work on cars/machines your entire life you always know of someone who did something stupid and started a fire or worse. I worked as a line mechanic for some time in a dealership. The guy working next to me was so dangerous, I demanded he get moved away from me. He was changing the fuel gauge sender in a full tank of a Jeep Wagoneer. He had fuel below him in a coolant catch pan.....He was working with a drop light and it dropped to the ground near the pan.......I yelled at him to get away from under there. He looked at me with a dumb look and said why as he bent down to pick up the drop light.....Nothing happened.....I left the area till he was done.... 2 friends were working on a car in a garage that was part of a bigger group of garages and there was a bar/building in front. They had a fuel line off in the rear of the car....gas was leaking on the floor.... a drop light hit the floor, started a fire and burned down everything.....the garages and the bar.building. Gas in the open or in a pan or on the floor......and a drop light is plenty dangerous....
#23 | |
Your releasing vapors that can easily ignite from just static.......If it did ignite it would likey ignite the entire container. These containers expand and contract with the temp. change.... Leave it alone and keep it out of the sun or away from a heat source.
#24 | |
You're correct about the pump , only install it in the drum when you need fuel , then take it out and re-seal the container tightly . |
#25 | |
Makes sense Thanks, |
#26 |
Icu 812
#27 | |
Liked 359 Times in 103 Posts
I again say it is not a good idea to pressurize a barrel which is not rated as a pressure vessel. If using air pressure to move gas out of a vessel/tank is such a good idea why don't gas stations and truck stops use that method? To the best of my knowledge all gas stations and truck stops use pumps. My 2 Cents Rick Cates Last edited by 63corvette; 04-04-2012 at 10:23 PM. |
#28 |
be careful out there.
#29 |
I'm probably using the wrong pump, I've got one of those big metal hand crank jobs from the local hardware store. It has a steel pipe that goes into the barrel and a few few of clear plastic hose going to the cans I fill.
Good info about venting the the swollen cans in the summer, I sometimes get a little worried when I go into the shop and see a drum all billowed out like that. It seems like the right thing to do is the vent it, From now on I'll let be. Thanks guy's.
2009 V/SA Record Holder |
#30 | |
Liked 279 Times in 68 Posts
Greg Hill 4171 STK |
