Old 04-07-2012, 12:57 PM   #1
REGGIE WINKLES
Liked 39 Times in 9 Posts
Default Re: o stock wagon gear question
Sounds a bit steep for a hydralic lifter stocker engine, Maybe alright for 1/8 mile. How much will that car need to weigh to make class? Stick or Automatic?
Reggie Winkles 2650/Stock
REGGIE WINKLES is online now   Reply With Quote
Old 04-07-2012, 05:36 PM   #2
GTX JOHN
Liked 2,516 Times in 701 Posts
Our O/SA runs 488 gears in good air and 513 at Elevation or Heat.
It runs a pretty high winding 318 Small Block Mopar but 351 may
like Slightly more gear.
O/SA National Recorder Holders
Old 04-07-2012, 06:38 PM   #3
Jeff Lee
Jeff Lee's Avatar
I dont know what gear it needs but keep in mind your better off under gearing a car than over gearing. Start a little conservative and once you get everything ironed out, try different gears.
You'll kill a lot of ET if you over gear but if you're close on the conservative side, you won't be that far off on ET
Jeff Lee 7494 D/S '70 AMX
Old 04-07-2012, 07:15 PM   #4
Tom Goldman
Tom Goldman's Avatar
Liked 887 Times in 239 Posts
I know of at least 1 higher class 351 running 5.40 gears, so you may not be too far off with
your guess of 5.60.
Old 04-07-2012, 07:48 PM   #5
sg794f
thanks for the responses, heres a little more info
the car will weigh 4050 lbs it will have a 351 c (4v) with a hp rating of 300
can for this motor is .420/.450 lift it will have a c4 trans (not sure of tranny gearing yet) looking at a 5000 stall convertor and it will run 1/4 mile
just want to get it out of the hole but not lay over at the top.
thanks kevin
sg794f is offline   Reply With Quote
Old 04-08-2012, 01:59 AM   #6
Jeff Lee
Jeff Lee's Avatar
Just to make sure we're on the same page, I see a 1971 Torino SW with a 351C-4V that is factory rated @ 285 HP. Is that the engine you are going to run? Then it is 305 NHRA rated HP, not 300 HP.
Also the specs are a .430"I / .450"E cam, Not .420" / .450".
After looking at what GTXJohn said about gearing (he runs SBM which would have a lot more bottom end than your Clevland), I would start with 5.38's. And you might be right on about the 5.57's.
I believe Pro-Trans will build a TF inside a C4 with better low gearing. Of course that isn't cheap!
For a wagon, I think those are pretty cool. Not Vista Cruiser cool, but I think next best thing.
Old 04-08-2012, 07:51 AM   #7
kwm
kwm's Avatar
Liked 4 Times in 3 Posts
The 4V will not run O/SA The Squire (the heaviest) has a 13.01 weight break with a rating of 305HP it is a natural K/SA.The 2V in the Squire has a weight break of 16.16 and a HP rating of 240 it is a natural P/SA
Kenny Miracle
P/SA 310
kwm is offline   Reply With Quote
Old 04-08-2012, 01:08 PM   #8
sg794f
i think you are correct about the specs....im just a dumb s/g driver, and am learning this stock game. ive already talked to dave and darren about the gearing in the trans and there gonna set it up for me.....im thinking about starting with the 5.38 gears. that seems to be the consensus from what im being told. and we are using the 285 hp motor. just want to have all my ducks in a row before we spend the $$$$ and we appreciate all of the help weve gotten on this forum
kevin sexton
brandon sexton future stock racer
