#51 | |
X2 I remember when we changed to a newly developed low drag pump for our dry sump. It was 4 to 5 HP.
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A |
#52 | |
#53 |
Because of the astronimical cost of even aquiring a passenger car 409 block and corresponding large port heads, yet alone the cost of preparing it the best I can for the class ( I'm not really in the income bracket to be playing this game ! ).... I keep re=assembling it with the good 'ol reliable Melling M55HV. The terror of spinning a bearing seems to always keep me on that side !
With the 30 W that I've been using, fully hot oil, I go through the traps at no more than 75 PSI. As mentioned, idle will be around 20-25. At 3000 RPM, it will be at 70. So, I'm thinkig that while my "high side" may be 15-20 pounds excessive, the drastic change that I see in oil pressure when cooler, is more of a viscosity issue. I was going to go to that real light stuff, but I think that my loose bearing clearances may not get enough "padding", and would simply get washed out because of too much "hemorage" ! err on the side of caution I've blown this thing up twice now. Once in 2005 because of a broken ARP rod bolt, and a second time in 2009 because of a failed Comp Cams tool-steel spring retainer. Can't afford to fix it again ! Thanks guys Remember, I'm there to add to the car count, and take my position at th ebottom of the ladder !
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
#54 | |
Liked 174 Times in 39 Posts
Another good comparison is John Clegg's SS/AM, 457 BBC, 3250 lbs, 7.90s, compared to a 522 BBC, 2900 lbs, 8.90s.
3207 D/SA, C/ED |
#55 |
Liked 359 Times in 135 Posts
WOW! You guys really take your oil serious around here. I work for Valvoline and we don't think about oil nearly as much as you.
#56 | |
Hey if you can dial it and drive you have just as good a shot at winning as the next guy. Keep up the good work. I always wanted a '64 with a 409/425 4 speed. Your car is a keeper.
#57 | |
Liked 759 Times in 379 Posts
3144 lbs. and I have NEVER raced in -2000 foot air! Running 8.90's yesterday with a restrictor plate in 3500 foot air with a 28.9x barometer ![]() Got to go, it's the weekend, I'm racing, something the ebay engine building chump above doesn't do! |
#58 | |
Actually we think about horsepower. Oil is just one piece of the puzzle.
#59 | |
Liked 373 Times in 129 Posts
#60 |
Liked 11 Times in 8 Posts
Dang it! OK Ed I'll bite, you raced @3500 ft. in New Jersey... didn't know there were mountains in that state. Either that or it was 95 degrees 80% humiditry plus your stated barometer. You went 8.90 with a RESTRICTOR PLATE, I knew Nascar used them on the super speedways to slow the cars down, I have to ask.... what are you using one for? NO really this is a legitimate question. So lets recap you state your car is faster than mine..it is, it runs 8 tenths faster with over double the cubes and weighs a whopping 170 lbs. more. Really I fail to see what all the puffery is about. However carry on. Joe
Joe Buchanan SS/BX 3117 |
