Old 05-06-2012, 11:34 PM   #1
Phillip marvetz
Phillip marvetz's Avatar
Default Re: Thermoquad issue or MSD box?
It was the carb, And does seem to be worse when I get it into the secondaries. The fun part was I put a 850 holley double pumper on to test, It was o.k with my 250 lb butt in the seat but Kelly had to put it into high gear to get the front end to come back down, Usually second gear will set it back down but this time it just went higher. The rear bumper is o.k but it was close,lol. Apparently the double pumper hits a little harder. I'll take a longer look at the carb this week. It was fine the last time the car ran late last year so it's a bummer that it had to act up this weekend.
Thanks for the ideas guy's.
2009 V/SA Record Holder
Old 05-07-2012, 02:21 PM   #2
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
Where's the pictures????
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 05-08-2012, 01:12 AM   #3
Phillip marvetz
Talking Re: Thermoquad issue or MSD box?
You have the 'in' with the picture guy, Hook me up.lol
Old 05-08-2012, 02:40 AM   #4
Dinsdale
Dinsdale's Avatar
I'm assuming this didn't happen with your beige car or the wagon! What day?
Dale Posnick
Old 05-08-2012, 12:18 PM   #5
Phillip marvetz
Sunday, 1sr round of eliminations. Kelly was in the right lane against John Sayer
Old 05-08-2012, 09:49 PM   #6
340Cuda
Liked 805 Times in 341 Posts
We chased a similar problem several years ago, it took us a long time to find it but there was a small chunk of RTV in one needle and seat. Ran fine until one float bowl ran dry. By the time you took it apart both bowls were full again.
Good Luck,
Bill
Old 05-07-2012, 03:02 PM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Just so long as it comes down before tripping the beams with your rear wheels! Jim
Old 05-07-2012, 04:03 PM   #8
GTX JOHN
Liked 2,493 Times in 700 Posts
George: Do you need the Vacuum Pull off............... I have run both ways and
it does not seem to make a Difference?
Old 05-07-2012, 09:40 PM   #9
George Mirza
John,
I usually will get a stumble if it's disconnected or blown out. I guess if you have enough tension on the air vlalve spring you can run without it.
Must be that 100 + degree desert air you race in, here in the northeast it's usually cold and damp, and we all know how Plymouths run in the rain. LOL
It's great that your feeling better.
Take care of yourself,
George
George Mirza is offline   Reply With Quote
