Old 05-08-2012, 07:59 PM   #1
scott welborn
Default Stock & Super Stock garage sale
Stocker parts 325-350/396
8 Arias C661 .030 pistons $350
8 Venolia 325/396 .030 $350
8 Venolia 325/396 .030 coated skirts $400
5 Lunati RL325-88 @107 $100 ea
Lunati RL 325-3 $100
Bullit 290H8 S607 $100
Bullit S4884 S6772 72 288 284 74 $100
Line performance 948 Q-jet intake $300
8 unmodifyed 948 Q-jet intakes $150 ea.
948 Holley intake $175
067 Q-jet intake $150
Woodro Josey 948 Q-jet intake 3 290 small plug heads bare 2 need work $900
Mopar 904 case chevy bolt pattern $250
Dynamic Chevy metric freshend since last used $650
Turbo 400 trans. Alm. drums 2.48 T.brake $1200
Turbo 400 2.75 gear set $450
Turbo 400 2.75 straight cut gear set $500
Powerglide trans. stock case ,2.98,turbo shaft, Alm. drum ,Hipster alm, t brake valve body $1400
A-1 torque convertor 6000 stall for turbo built for SS 300-350 SP6558 350A-20 CZX 100 $700
12 bolt chevy 4.33 pro gear $225
12 bolt chevy 3.90 gear $125
Ford 9" 5.86 pro gear $225
Moroso front trick springs for 68-72 Chevelle or comp. GM bodys $75
Moroso weight box $65
2 M/T Frontrunners 29" 12 passes $150
2 Weld Magnums 15+10 5.5 rear space 4 3/4 bolt W/30+9 lightweight Hoosiers $700
SAR prepped late model Q-jet $595
2 Rodcester 4GC cores $150 ea.
HP Q-jet kit Tk. top gasket .135 window n&s 2 4 hole tk. base gaskets fast cpa $60
Call Scott 803-210-8573 stocker204@yahoo.com
scott welborn is offline   Reply With Quote
Old 05-09-2012, 05:45 PM   #2
DK FRAZIER
Default Re: Stock & Super Stock garage sale
Scott,
I will take the weight box give me a call
thanks
Doug
Doug Frazier D/SA 2038
DK FRAZIER is offline   Reply With Quote
Old 05-13-2012, 12:11 AM   #3
66 BELAIR
You have a pm.
66 BELAIR is offline   Reply With Quote
Old 05-18-2012, 09:16 PM   #4
DK FRAZIER
Scott,
Thanks again
Doug
Search this Thread:
Advanced Search
