Old 05-31-2012, 03:34 PM   #3
FED 387
Liked 336 Times in 183 Posts
Default Re: Weight savings between enamel and lacquer paint?
a lot depends on the ingredients of either one--- cheap ones will be lighter in weight and the better quality paints will weigh more simply because of the ingredients----lacquer weighs about 6-7 pounds per gal while enamel is about 10-12 per gal--- remember tho that enamel is more durable while lacquer will chip easier---also consider the primer used primer can be heavy about 11-14 pounds per gallon -- price will be cheaper for lacquer and easier to apply while enamel tends to be pricier and more difficult to have a good finished results
