Old 07-08-2010, 04:47 AM   #11
Chris1529
Liked 70 Times in 29 Posts
Default Re: Legal Ford 5.0 head with screw in studs
are you guys having trouble with your stock rocker arms?
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 06-02-2012, 06:58 AM   #12
Earle Holt
Liked 4 Times in 1 Post
What is everyone's take on this? The Rocker Arms section was updated Jan. 19th, 2012 and says:
"OEM or aftermarket rocker arms permitted. Needle/roller bearing pivots and roller tips are permitted for all applications. Must remain same design as original application (ie: stud mount must retain stud mount, pedestal type must retain pedestal type and shaft type must retain shaft type. Stud girdles prohibited) Stamp steel OEM and OEM-type rocker arms may be reinforced."
also under the cylinder heads section it says:
"The following are permitted: polylocks, jam nuts, screw-in larger diameter rocker studs, or pinned studs..."
I'm finishing up a stocker 5.0 Mustang. Using stock rockers, not rollers, would you say that screw-in studs are legal? I'm getting conflicting feedback on this.
Thanks
Earle Holt 1055 Stock
Earle Holt is offline   Reply With Quote
Old 06-02-2012, 12:38 PM   #13
west coast
Liked 227 Times in 74 Posts
I ask this same question to Pat at Phoenix National earlier this year. He said it was up to Bruce to make this call. I have a set in the works with screw in studs but have stopped until I find some more info just have not sent any email to NHRA lately, I need to do this but the start of race season interfered. Here what I have done since then order ford part# M-6564-B351C from Paul at RACEMART( this is the best price on them) this is an adjustable roller rocker which helped out in time to adjust your valves. I have a set of stock after market rockers I think they are comp cams stuff that is better material, that is now obselete for me.
west coast is offline   Reply With Quote
Old 06-02-2012, 01:00 PM   #14
mopar jeff
mopar jeff's Avatar
For me the issue is making valve adjustments. Not messing with shims makes the job a lot easier, but that being said, I still have the stock ones at this point.
Jeff Interlicchia
7077 D/SA 1998 Pontiac Firebird LT1
J707 E/T 1966 Dodge Coronet 500
mopar jeff is offline   Reply With Quote
Old 06-02-2012, 02:01 PM   #15
NWDragracing
NHRA allowed the use of guide plates and studs prior to the new roller rocker rule.
They have also allowed the stud and guide plate kit from Crane Cams since the 1990's not only on the 351-C but also the SBF's. Their kit consists of studs, nuts and a Nylon material style guide plate.
Look at Rory's previous message; he runs a fully adjustable rocker arm system like many others.
If you select the proper guide plate, stud and pushrod, you do not need to machine the pad to install guide plates.
NWDragracing is offline   Reply With Quote
Old 06-02-2012, 11:34 PM   #16
7423
[QUOTE
Thanks[/QUOTE]
Screw in studs are legal if they screw into the original 5/16" course thread holes in the pedastal. I assume that is not the answer you were looking for. I confronted Bruce with this topic a couple years ago.
7423 is offline   Reply With Quote
Old 06-03-2012, 01:28 AM   #17
NWDragracing
So, under this assumption, the Chevy Big Blocks would be illegal by using the 9/16" studs???
Old 06-03-2012, 09:53 PM   #18
Earle Holt
Thanks for your input guys. I appreciate it!
Old 06-06-2012, 05:54 AM   #19
Earle Holt
I've asked Bruce for clarification on this.
Old 06-06-2012, 11:09 AM   #20
7423
Very interested in what his response will be.
