Been there, and done all that, Greg ! On my old 64 Pontiac convertible, that's almost exactly how my heads were done. I sold that car to build this one !
One thing is for absolutely sure... there is no possible way on earth that I could achieve .100" piston to valve on the exhaust, without taking 20 degrees dutration out of the cam, and milling the piston a WHOLE lot ! It's all good... really. and the trouble is that it never really does "nose over"... especially down at sea level in Mission. Exhaust valve is always good... but probably due to a much more gentle lobe. No bounce. It's just the damn intake. BTW, the track... sea level ( as opposed to dyno )... yes, that was a lesson ! Alan, much longer valves create a new problem in geometry... particularly on the exhaust valve, because of the angles of the rocker stud in relation to the valve. Not ideal at all. Not to mention, I already have my valves sunk into the heads at least ..050" deeper than stock ( piston to valve is a real problem )... so longer valves would be way up there. Good news is, yes, I can fit 1.55 spring. That was my old combination. Results were the same. Maybe I should mention that my heads, at .510" lift, flowed 288 / 212. Certainly not the potential of a large port BBC. The right retainers and keepers ? yup.... been chasing that one for a while !
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
Guest
Posts: n/a
When I first started racing the Firebird, I changed the rear gear in it. The first time I ran it at the Etown national event it started popping and banging at around 6700. Around 100 ft before the finish line. After the race I checked the valve springs. Found them to be at 200 and 380 open. Bingo! I thought. Changed the springs and retainers. Had 450 open. The next race I almost able to get to the traps ! I figured what is wrong now. When I got home I was going swap a fresh engine anyway.
When I took that engine apart to get the cam and lifters and other assorted parts, I found 3 loose pucks on the bottom of the lifters. The camshaft was a Bullet. I checked the numbers on the cam for the lobes. When I looked up the lobe profiles, the were dwell torque lobes . When I asked John Partrige about this, he told me those lobes were never meant to run over 6500. He told me that I need a asymmetrical rpm style lobe. So I ordered one from him. The cam he sent me went to 7400 with no problem, and I never broke any valvetrain after that. You are on the right track, sounds like you need a profile change. Last edited by Todd Hoven; 06-03-2012 at 08:30 AM. Reason: Added info |
#3 | |
Liked 327 Times in 121 Posts
#4 | |
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock |
#5 | |
Liked 7,754 Times in 1,741 Posts
Liked 1,831 Times in 415 Posts
Aubrey, those flow numbers are not nearly as low as you think. I'm betting if you sent the heads to the right person to have them done, they'd be even better, especially with the right valves. You have enough cylinder head to make good HP at 6800 RPM with a 0.060" over 409, the biggest problem is probably the intake manifold.
For your cylinder head flow, your cam is too big, especially if it has some sort of wildly aggressive lobe on the intake. Mark is right, the right headers could reduce the need for all that duration on the exhaust, provided you even need that much now. With good valvetrain control, 0.055" on the intake and 0.075" on the exhaust is plenty of clearance. With the right cam lobes and the right valvetrain, control should not be a problem. Working with pushrod length will probably solve some of the problem with longer valves. There's no such thing as "ideal" valvetrain geometry in Stock Eliminator for most engines. The restrictions of the class prevent it. We're not anywhere near ideal with the big blocks, yet we have not had a single valvetrain failure in over 5 years. I think 2006 was the last time we had a valvetrain failure of any kind, and the problem was solved with the correct rocker studs.
Alan Roehrich 212A G/S |
This is GREAT !...
I'm 3 times as confused as I was before ! ! ! HE HEE !! Facts and numbers The engine makes about 45 HP more than anybody ever did with even a "resembling Stock" 409 before. Speed through the traps is at least 4 MPH faster than anybody ever went. My bottom end is legal... piston/rod weight is dead on, combined combustion chamber volumes of the block and head, are safely within spec. All that I have done different from everybody else with these things, is a big-azz camshaft, and big-azz headers ! Seriously, when tested... went from an EXCELLENT set of 1 7/8" tube, to my own 2" stepped to 2 1/8". Torque curve moved up, peak torque went up by 17 ft lbs, and the engine made 21 more HP. The old "torque thinking" just doesn't seem to apply to this short stroke engine. Unrestricted ( for the CID ) carburetor CFM, I believe, is also a reason to pursue the escape of the mid-range torque concept ? I dunno ?.... other than the intake valve going out of control... this damn thing really works. So, at the moment anyway... fix what's "broke" ( square cam lobe )... and leave alone, what seems to be a really good "package". assymetrical cam lobe ? THAT may be the very compromise that I need ! You guys are amazing... Between the support I get here, and the practically "out of body" experience of attending places like the race in Mission... I'm getting hooked on this REALLY bad !
Liked 544 Times in 213 Posts
Opening ramp is different than closing ramp. Rate of lift might be fast open and softer on the closing side. A symetrical cam has the same opening and closing ramps... Cam companies tried all kinds of unique designs. Even going back to my days racing in Jr. Stock around 1970 there were distinctly different cams. We were limited to stock springs and pressures and valve train. Some cams we used could not be run much past 5800 rpm and one would run right up past 6000 with no problem....Stickshift hydraulic cam small block Chevy.
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 06-03-2012 at 12:34 PM. |
Liked 644 Times in 193 Posts
Aubrey could you go to a taller tire to kill some rpm through the traps? Some great feedback on this thread
I'm paying attention here... so,
Cams aren't that expensive. I already have a set of good "civilized" headers. I'll get two cams. One how I "feel" it should be. The other with 10-12 degrees less duration, and run it in the correspondingly somewhat lower RPM range. I have the 4.88's to use in place of my current 5.13's. For testing purposes, I'll use my current heads. I'll make that my goal before the end of this season. Currently, the engine never sees below 4500 RPM on a run.
