"Currently, the engine never sees below 4500 RPM on a run"
You'd better be making peak torque no higher than 4300 rpm. 200 rpm above peak torque is the basement. If you drop below that it won't recover.
Scott Wilcox 2193 3x National Champion SS/A, SS/B, SS/K, SS/L, SS/AM, A/SM, C/SM, B/A, C/A, G/A, H/A Last edited by Pvt Parts; 06-03-2012 at 06:45 PM. |
Liked 1,880 Times in 422 Posts
You might get by with a 3/8" x 0.125" wall. Consider a dual taper, Trend has a dual taper 3/8" - 7/16" pushrod, it's 3/8" on the ends, and 7/16" in the middle. Trend will measure for you to see if they can make something work.
You do not have to run a single spring any more. They opened the spring rule up. Not sure what you mean about the headers. If your headers are 33-34" long, with a 16" long collector, that's about what I was suggesting, length wise. A merge collector will fit where a plain collector will.
Alan Roehrich 212A G/S |
#3 | |
My pushrods ARE those ridiculous, almost solid wall things. No more "stock spring arrangement" ? HHMMM. they really are loosening those rules, aren't they ? The header tubes can finally merge together, under the frame, at about a 30 degree angle back from straight out the sides, approximately 12" from the outside of the car. A merge collector piece such as this one that I just used on headers that I built for a customer car.... would actually exit out from under the front fender, extending about 6" outside the car ! Can't be done.
Aubrey N Bruneau 6409 C/S 62 BelAir sport coupe, 409 HP 409 |
Aubrey ,You can get Manley to make valves on there Gen2 custom stainless blanks.Also look at how much coil bind clearance you have ,too much may cause spring bounce or surge.We agree with Billy Nees and others ,the headers are probably to big.We see engines that get The National Dragster Tune Up ,Big headers,Big carb,bag of ice on the manifold and take 2 quarts of oil out
I know, Bill... the 'ol "bigger is better" thinking.
I suupose I could try and justify it by saying that it alreadhy has the "bigger" carburetion... and that I was just trying to follow suit ? Anyhow I just had a lengthy conversation with the Stocker guy at Comp Cams. One thing I know for sure now... you guys with the BBC's, spinning big RPM, are NOT using a lobe that resembles this intake lobe that is on my cam. He confirmed that it is NOT an RPM stable lobe... especially with inherently heavy valves / high ratio rockers. So, I have taken heed to everybody's recommendations and advice. And it looks like I WILL build a new set of headers. If I can retain even half of what I learn around here, maybe I won't blow up again... and maybe even go faster ? ! thanks guys
#6 | |
You're in good hands now if that's who you're talking to. You're going to love what a good stable camshaft and valvetrain does for your engine program. You will now be able to use the cylinder head flow and the carburetors you have. Let me know if you want to see about getting some REAL good stainless valves for that thing. When you get the engine right, you should be able to use about a 3.05 first gear and a 5.14 rear gear. Just be ready to get it in second gear real quick.
Yes Alan, I called Tim Cole, as you recommended. He took it like a hot potato, and passed it off to Chris Padgitt !
Ah yes, they too, want me to go away ! Chris is the fellow who originally did this lobe for me in 2004. Like so many, he too, I believe, catagorized this lump as a "torque engine". I dunno ? maybe I broke that "mold" ? Anyhow, I'm REALLY excited about this lobe that he came up with ! Also, because I learned from here, that I'm not limited to a single spring anymore... he discovered a dual spring that will fit right in, standard length valves. Valves.? YOU BET ! I'll be bugging ya' ! With the bit of tire spin that I get... second gear already comes instaneously ! The transmission gear change ( probably actually a tranamission change ) will be a winter project. At the moment, get this dealt with.
