#101 | |
Liked 534 Times in 143 Posts
Lets just say that if I ever crash my car, I won't die from the impact. It will be from strangulation. ![]() |
#102 |
Tim,
Leakdown test was performed cold. Engine hasn't been run in 2 weeks. -Ben |
#103 |
Ben,
First of all, I'm no expert so take this for what it's worth.... 1) After dyno session, did you back the rockers off when it sat until you got it in the car? 2) When I do a leak down, I typically run the car up to 140-150 then attempt to zip through the test with warm cylinders. The cylinders that are over 5% I would smoke test, go by a cheap cigar and have it over the carb/intake opening and exhaust port/ header tube when performing this scientific test... don't laugh, it works. Other than everything else mentioned, get it to a track or bring it up north. My trans builder has a chassis dyno and has had many BBC on it. Sounds like a fun mystery! Tim |
#104 |
Liked 1,909 Times in 427 Posts
Now the chassis dyno sounds like an excellent idea, that's even better than track time. you test the whole car, and you can hook diagnostic equipment to it and then duplicate the problem.
Alan Roehrich 212A G/S |
#105 |
I've actually been thinking about the chassis dyno idea for a couple of weeks now. There's a speed shop with an in-ground dyno about 10 miles from my house. I'm not certain how experienced the operators are in terms of diagnostic abilities, but at the very least, I'd be able to see how it responds at full throttle under load.
-Ben |
#106 |
Liked 3 Times in 2 Posts
Ben, make sure you have plenty of clutch pressure before you put it on the chassis dyno. Good luck.
Arnold Greene IHRA/NHRA 2420 A/S, B/S |
#107 |
Arnold,
Thank you. I wouldn't have thought of that. |
#108 |
Have you looked at the valves to make sure they all open the same as you bump over the motor(no mess that way) If they all seem to open all the way chances the cam is ok. If this car is an automatic I would unbolt the torqconverter and see what difference that makes. make sure you push it back out of he flywheel.
#109 | |
Liked 254 Times in 78 Posts
Mike Moller Last edited by MikeMoller; 06-07-2012 at 11:16 PM. |
#110 |
Hi Ben,
This is my first reply on this site, so hopefully I get it done correctly. Before I describe a similar situation which I had, trying to chase down a "miss" in the engine, and what was causing it, I have one question; do you have a spacer plate below your carburetor? |
