Old 06-18-2012, 06:45 PM   #3
68camaroSS
Default Re: Strange Master Cylinder Plumbing
Originally Posted by Jim Kaekel View Post
Here's a heads-up that should help as I did this about 1-1/2 yr. ago. If you are switching from a GM to a Strange Master Cylinder, you will first need to plum in a residual pressure valve on each port, which type depending upon if you are using disc or drum brakes. Strange sells these as well. The Strange master cylinder does not have this feature built-in like the stock GM master. I ran a 8" length of 3/16" brake line from the master to each valve as I was told to locate the valves as close as possible to the master by Strange. The residual pressure valves have 1/8" NPT ports and come with 1/8" NPT to 3/16" I.F. adapters.
do any of the aftermarket master cylinders have the residual pressure valve built in?
68camaroSS is offline   Reply With Quote
