Old 06-22-2012, 08:48 AM   #4
SSDiv6
Default Re: Camaro/Firebird electric smog pump--what years
Originally Posted by FED 387 View Post
are these electric?? wanna put it in a remote place not on the firewall--- why this pump instead of the GM pump??
Yes, it is electric, used on the 2000 Cobra R Mustang; preferred because it pulls the most vacuum when compared to other pumps. It pulls 10" of vacuum.
If you plan to use a PCV valve, use P/N E5ZZ-6A666-A; is designed for boosted applications.
Also, there is a good GM pump if you can find it; P/N 22062562, and the electric connector is P/N 12085485.
This pump was used for brakes on Buick GN and some Cadillac applications.
