Old 06-25-2007, 06:35 PM   #1
Tom Turner
Default
I went through this with NHRA on my Corvette stockers (Fred and Barney, not the 96). As early as 1995, AC Delco saw fit to replace MOST brass radiators with Alum/plastic units; I asked: " If the O.E replacement is Alum/Plastic, why is THAT not legal?" They answered with a question: "is it a direct bolt in replacement?" The answer is "yes". It's LEGAL! The unfortunate part here is that AC Delco neglected to make a direct fit replacement for the 69 and 70 model years (Camaro and Nova) due to bracketry on the tanks as opposed to rubber saddles on the bottom of the core support and a sheet metal saddle bracket/fan shield on top like the 71-72 cars. A crafty guy would sneak a 20044 AC Delco radiator in there with some 72 saddles and top mount. Done nicely it would take a pretty serious purist to notice and "who cares?" By the way, my trick alum/plastic radiator with my Flex-A-Lite dual fan attached is a whoppin' 1.5 lbs lighter than my brass junker. I took nearly 10 times that much weight off the nose with an ATI balancer and a Meziere water pump; both legal. It's another rule that could stand a little "enhancement"
Tom Turner is offline   Reply With Quote
Old 06-26-2007, 01:07 AM   #2
Bob Berleen
Default fitment
there are so many combinations in stock that you are sometimes only able to find copper and brass oem radiators. if you dont run a muscle car combo the parts are pretty hard to find
Bob Berleen 6910 STK
65 Bel Air Wagon
P/SA 6910
ET 691Q
Bob Berleen is offline   Reply With Quote
Old 06-28-2007, 11:24 AM   #3
FlyingW
FlyingW's Avatar
Default
all I am saying is if some stockers are allowed to run them than everyone should be able. I have ran both in the car and saw ZERO et change yes it did cool faster. So I get going hot laps like I did in valdosta,ga 2 years agao and Iam hotter than some one with an aluminium radiator. Who has the advantage there?????????????????????? I am just trying to get everyone to be able to have the same cooling abillity...thats all......And by the way a stock 2 core radiator weights the same as a 4 core aluminium......
FlyingW is offline   Reply With Quote
Old 06-28-2007, 01:17 PM   #4
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default
That's questionable reasoning when it comes to stockers. Some production cars had aluminum radiators as far back as the mid-1960s, but that has never been a justification to allow them for every competitor. Corvairs came with air-cooled engines and no radiators, so we should all be allowed to not run a radiator???? Some stockers are allowed to run aftermarket 780 cfm Holleys, so we should all be allowed to run them???? I'm not objecting to the aluminum radiators, just that the argument should be more substantial. In the interest of (1) providing all cars to be equallly equipped so they can compete in race conditions where there is rapid turn around for rounds ("hot lapping"), (2) safety of equipment and (3) protecting the $$$ investment in race engines in intense situations are all good reasons to allow them.
There is so little weight advantage with the aluminum radiators that weight reduction is not a serious issue. The majority weight of a radiator is in the volume of water it contains. It's like worrying about the weight of Hard-Blok when the volume it takes up in the water jackets is normally filled with water. The difference on a BBC is only about 4 pounds. Like you said, your high performance aluminum radiator weighs the same as the OEM.
Old 06-28-2007, 03:04 PM   #5
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Thumbs down
all I am saying is if some stockers are allowed to run them than everyone should be able.....
There is a place to run what everybody else runs, it's just not stock.
The combos are based on the intelligence of the individual putting the combo together, (see Bob Shaw) not on getting the rules changed after the fact.
If you want a racecar with an aluminum radiator then build one that has one.
Bob
Bob Mulry 7516 STK
A & M Motorsports
Old 06-28-2007, 03:53 PM   #6
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Default
Kinda sorta like 'late model computer cars can shift automatically, so everyone should be allowed to use the E-Shift controller'. Right?
Old 06-28-2007, 08:10 PM   #7
RocketBlock
Default
Late model engines come from the factory with not only aluminum radiators but roller lifters. They may not be faster but they sure don't chew up camshafts. Therefore, all of us should be allowed roller lifters. That would not only save parts but could keep oil off the track when a cam fails and takes out the valvetrain and possibly the entire engine. That would also be a safety consideration.
I get sick of the safety issue getting thrown at everything. I'm sure it's worn thin with NHRA also.
RocketBlock is offline   Reply With Quote
Old 06-29-2007, 02:33 AM   #8
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
Default
Yea, I think it would have to be factory to be allowed. Just like the e-shift that beard pointed out, except that I think that you should only be allowed to run that if you use the factory computer.
Also, I dont really see it as an advantage, you just have to know how to get it cool quick. I have no problem hotlapping our car at local bracket races, and I dont even have an electric water pump.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
