View Poll Results: Fuel injection? Do you run in open loop or closed loop
Open Loop 80 65.04%
Closed Loop 43 34.96%
Voters: 123. You may not vote on this poll
Old 07-19-2012, 09:44 AM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Fuel injection? Open or Closed loop?
Originally Posted by Marine One View Post
If you are concerned that the ambient temps are causing the ECM to pull timing, just adjust / eliminate the amount of timing being pulled via the AIT mapping.
Don't really know anybody pulling timing with it. Most slightly tweak air/ fuel with it.
Ed Wright 4156 SS/JA
Old 07-21-2012, 04:42 PM   #2
NewHemi
NewHemi's Avatar
Just thinking, since we have always run closed loop, that could explain our inconsistency run to run when weather changes a little, but doesnt seem like enough to cause the kind of changes we have seen.
Our tune is tight enough, that we could certainly run open loop without worrying about breaking anything.
Hmmmm, next time out, whenever that might be, I think I will try open loop to see.
David
The New Hemi Guy
NewHemi is offline   Reply With Quote
Old 07-21-2012, 07:32 PM   #3
HTMtrSprt
NEVER run a race car in closed loop.
HTMtrSprt is offline   Reply With Quote
Old 07-23-2012, 02:34 PM   #4
Mickey Whaley
I thought you could only run 1 loop as the other would adjust the fuel for the weather?
Mickey Whaley is offline   Reply With Quote
Old 07-23-2012, 09:41 PM   #5
Ed Wright
Ed Wright's Avatar
Micky, open loop makes no corrections.
Closed loop attempts to always correct to the values in the Target Air/Fuel ratio table.
I'm surprised at how many use closed loop in this poll.
Old 07-30-2012, 12:52 AM   #6
HawkBrosMav
Liked 302 Times in 73 Posts
you guys might want to read the rulebook....
FUEL INJECTION
Fuel injection must retain OEM throttle body(s), plenum, and
manifold. If OEM throttle body(s) was equipped with electronic
throttle control (i.e., drive by wire), the throttle body(s) may be
adapted to mechanical throttle linkage if an aftermarket OEM-type
electronic-fuel-injection system is used. Larger fuel injectors
permitted, provided no modification or redrilling of manifolds is
performed. Electronic fuel injection must be closed, OEM-type
system
; i.e., may monitor only engine functions. Monitoring of
vehicle performance criteria, wheel speed, driveshaft speed,
vehicle acceleration, etc. by fuel-injection system prohibited. All
aftermarket OEM-type electronic fuel injection must be NHRAaccepted. A current list of NHRA-accepted electronic-fuel-injection
systems is available on NHRARacer.com. Open-loop systems
permitted on production vehicles as equipped with OEM electronic
fuel injection.
See General Regulations 9:1.
not saying it could be checked very easily but 99% of you are illegal running in open loop..
Brad
Old 07-30-2012, 05:17 AM   #7
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
as i read all this i'm reminded of some classes/training i've took over the years......when you go WFO, oem stuff IS in open loop.
Old 07-30-2012, 08:22 AM   #8
KRatcliff
Liked 534 Times in 143 Posts
FUEL INJECTION
system
fuel injection.
Brad
Brad,
I am not sure you are reading that right. It says that it must be a closed system reading only engine functions, not driveshaft speed etc.... The "closed" system part of the rule doesn't have anything to do with "Open loop/Closed loop" as far as O2 monitoring.
The later part of the rule that you put in bold clarifies that.
KRatcliff is offline   Reply With Quote
Old 07-30-2012, 10:31 AM   #9
art leong
FUEL INJECTION
system
fuel injection.
Brad
Some stock systems run in open loop. Till certain parameters are met. The turbododges are in open loop at wide open throttle.
We are not illegal. I had went through an NHRA electronics teardown. And they had asked it I running open loop.
Art Leong 2095 SS
