Liked 3 Times in 1 Post
PJ, I heard the rocker ratio was dropped too. I called Travis and he said it was still in full effect. He was the one who checked them at the Allstars this year. Lift at valve as well as ratio will be enforced.
Wade O |
Liked 325 Times in 50 Posts
If your rocker has no number (ratio) stamped on it, don't worry about it. I was thrown out because mine were stamped 1.65 and the rules said 1.60. The cam checked ok. Without the numbers nobody knows or cares I think.
Jeff Teuton 4022 STK |
Liked 1,880 Times in 422 Posts
They can, and will, check lift at the valve, and then lift at the cam. From that they will check rocker arm ratio. If the ratio is greater than what is in the blueprint specs, they will throw you out.
Feel free to ask Travis Miller, or Dave Ley about this, they will explain it to you. There are also several threads on the subject that explain why and how about rocker ratio. I have seen people thrown out for rocker ratio.
Alan Roehrich 212A G/S |
Rocker ratio is not constant in the swing of the arc. Check max lift at the valve and at the cam all you want and you will never catch it that way, unless you went crazy and tried to go from something like 1.6 to 1.8
Chad Sheets | STK 319 | 10.69 | 1.39 Last edited by Marine One; 07-20-2012 at 11:46 PM. |
Liked 58 Times in 18 Posts
If they check lobe lift and x it by the correct ratio it better be the same or damn close to what it checks at the valve, you will always loose some from spring pressure but not the difference between 1.5 and 1.6, but when was the last time they checked lobe lift ? and is that something there doing now ?
Liked 653 Times in 89 Posts
As per Danny and Bruce at Chicago nationals this year any ratio is allowed.
Dalles Glens corvette had 1.55 rockers from comp cams on his lt1 corvette and 1.5 is the spec .Danny told me all NHRA cares about is that the cam checks And that is fact.
Charley Downing 3548 STK Last edited by Charley Downing; 08-03-2012 at 04:00 PM. |
Liked 5 Times in 4 Posts
Charley,
Wade O. said Travis checked all the rocker ratio's at Chicago so how could Dallas Glenn be legal with 1.55 rockers when 1.50 are in the blueprint spec. Travis can you clear this up for the guys going to Indy. Thanks |
