View Poll Results: Fuel injection? Do you run in open loop or closed loop | |||
Open Loop |
80 | 65.04% |
Closed Loop |
43 | 34.96% |
Voters: 123. You may not vote on this poll |
Thread Tools | Display Modes |
I thought you could only run 1 loop as the other would adjust the fuel for the weather?
Micky, open loop makes no corrections.
Closed loop attempts to always correct to the values in the Target Air/Fuel ratio table. I'm surprised at how many use closed loop in this poll.
Ed Wright 4156 SS/JA |
Liked 302 Times in 73 Posts
you guys might want to read the rulebook....
FUEL INJECTION Fuel injection must retain OEM throttle body(s), plenum, and manifold. If OEM throttle body(s) was equipped with electronic throttle control (i.e., drive by wire), the throttle body(s) may be adapted to mechanical throttle linkage if an aftermarket OEM-type electronic-fuel-injection system is used. Larger fuel injectors permitted, provided no modification or redrilling of manifolds is performed. Electronic fuel injection must be closed, OEM-type system; i.e., may monitor only engine functions. Monitoring of vehicle performance criteria, wheel speed, driveshaft speed, vehicle acceleration, etc. by fuel-injection system prohibited. All aftermarket OEM-type electronic fuel injection must be NHRAaccepted. A current list of NHRA-accepted electronic-fuel-injection systems is available on NHRARacer.com. Open-loop systems permitted on production vehicles as equipped with OEM electronic fuel injection. See General Regulations 9:1. not saying it could be checked very easily but 99% of you are illegal running in open loop.. Brad Last edited by HawkBrosMav; 07-30-2012 at 12:59 AM. |
Liked 8 Times in 7 Posts
as i read all this i'm reminded of some classes/training i've took over the years......when you go WFO, oem stuff IS in open loop.
without losers,winning means nothing. |
You are absolutely correct Tom. P.E. (Power Enrichment) mode is Open Loop. Closed loop target air/ fuel ratio is always 14.7-1 unless they have a Lean Cruise Mode. Then usually over 15-1 or leaner. Those are normally "Export" calibrations, as the cats used now are not efficient that lean. Most factory calibrations are actually overly rich in P.E. mode. Richer than we run our cars. Most GM calibrations are closer to 12-1 from the factory.
#6 | |
Liked 534 Times in 143 Posts
I am not sure you are reading that right. It says that it must be a closed system reading only engine functions, not driveshaft speed etc.... The "closed" system part of the rule doesn't have anything to do with "Open loop/Closed loop" as far as O2 monitoring. The later part of the rule that you put in bold clarifies that. Last edited by KRatcliff; 07-30-2012 at 08:25 AM. |
#7 | |
#8 | |
We are not illegal. I had went through an NHRA electronics teardown. And they had asked it I running open loop.
Art Leong 2095 SS |
Open loop.
Unless you have an o2 sensor for each cylinder (with correction factors to support each cylinder) then you could argue some advantages to running it closed loop. |
Open loop is probably better for bracket racing consistency I would think because the car doesn't adjust itself going down track.. however, would closed loop be better in a heads up run or when you need that extra power if the car is properly tuning itself downtrack? Has anyone ever tested to see which method was strictly quicker?
