View Poll Results: Fuel injection? Do you run in open loop or closed loop
Open Loop 80 65.04%
Closed Loop 43 34.96%
Voters: 123. You may not vote on this poll
Old 07-30-2012, 08:13 AM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Fuel injection? Open or Closed loop?
Originally Posted by Tom keedle View Post
as i read all this i'm reminded of some classes/training i've took over the years......when you go WFO, oem stuff IS in open loop.
You are absolutely correct Tom. P.E. (Power Enrichment) mode is Open Loop. Closed loop target air/ fuel ratio is always 14.7-1 unless they have a Lean Cruise Mode. Then usually over 15-1 or leaner. Those are normally "Export" calibrations, as the cats used now are not efficient that lean. Most factory calibrations are actually overly rich in P.E. mode. Richer than we run our cars. Most GM calibrations are closer to 12-1 from the factory.
Ed Wright 4156 SS/JA
