Old 08-09-2012, 09:55 PM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Default Re: jerico dr4 fluid
Mobil 1 75-90
Old 08-09-2012, 10:05 PM   #2
james schaechter
Liked 1,439 Times in 301 Posts
I think any synthetic would be fine, but I really like the lightweight redline. I have been using that for about 6 years now. 1 quart. The big thing is to change it out periodically. I change it once during the season and again in the off season when we look it over. Never had any lube related issues, but I have seen some where they never changed the fluid out and cleaned the magnet. More junk running around inside is not a good thing. The magnet is strong,but it will get "full" of stuff if you don't tend to it once in awhile. I also added some good side drain plugs with rare earth magnets to grab as much debris from wear that I can.
James Schaechter 3163 STK
Old 08-09-2012, 10:10 PM   #3
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
is that redline's shockproof you guys are talking about?
i run it in my harley...
Old 08-09-2012, 10:20 PM   #4
Jamie Greening
Yes. It's the lightweight shock proof gear oil. That stuff clings to the gears great. That's why you can get away with one quart.
Jamie Greening is offline   Reply With Quote
Old 08-10-2012, 12:15 AM   #5
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,377 Times in 502 Posts
I was running the red line shock proof but jerico told us to take it out and use mobil-1 75/90 instead.
'65 Mustang SS/L & L/SA
Old 08-10-2012, 02:08 AM   #6
Rory McNeil
I`ve also been using the Redline "light shock" in my Jerico (the blue stuff), I used to fill the trans to the fill plug, but I think I will try 1 quart next fluid change.
I also use Redlines "heavy shock" oil (the pink stuff), in my diff, as mentioned, this stuff clings like crazy! Earlier this year I pulled the diff cover after the car sat over the winter, and there was still oil clinging to the top of the case.
And speaking of Jericos, am I the only guy who has troubles with gear oil seeping out the front? Its not the input shaft seal, i`m guessing it must be from the cluster shaft area. It doesn`t drip onto the ground, but always seems to have a drop sitting at the bottom of the scattershield.Any easy fix?
NHRA 6390 STK
M/S 85 Mustang
Old 08-10-2012, 06:23 AM   #7
james schaechter
No, you aren't alone, but it might be time for a new steel bushing in the front of the case. When that gets loose, bad stuff can follow. You can order a new bushing from Jerico if the case is ok. If you know someone that can machine a bushing, you can do a custom one if the hole for the bushing is loose.
Old 08-09-2012, 10:20 PM   #8
james schaechter
Yes. It is sticky and slippery at the same time.
Old 08-09-2012, 11:42 PM   #9
Run to Rund
Liked 54 Times in 27 Posts
I use Torco RTF (racing trans. fluid) in all my manuals, car and truck.
