Liked 544 Times in 213 Posts
Most later 4KY's have the coil mounted under the blower/flywheel.
The coil wire is part of the coil and it is a magneto type ignition. The coil wire is at a very sharp angle as it routes to the spark plug. The vibration of the engine and the bad angle of the wire often causes the wire to fail. It is a carbon core type wire and you lose spark as the unit gets hot...... Possibly your problem.... Fuel pumps are a piston design and even though you see fuel coming out cold.....it could still be your issue. If it was never changed and the unit has some hours on it.....it may be your problem.... The solinoid on the carbs fuel bowl energizes with the pump and allows fuel to flow. If has a ground wire and a B+. They don't fail often but do get stuck from a unit that sat with fuel in it....
Liked 41 Times in 9 Posts
I had an issue with my RV Onan generator shutting off a few years ago .......Matt Schurman is the go to guy.....D1 super gas racer....brought the RV to his company in northern NJ ...( mind you I live on Long Island and RV repair places here are crooks) and he found it was a coolant sensor.....did a complete tune up on it which included removing this monster from the truck to get to the sensor for $700....was totally happy with Matt and his work....great guy to do business with.
Joe Franco SS176 |
Joe that was a difficult job as I recall....getting the generator out and back in was no bargain....
We have had others just as bad........ Front mounted diesels.....no slide and have to remove the front of the M-H to get the generator out.... Matt and I have worked together for 20 years now..... Rich
Rich Biebel S/C 1479 Stock 147R Last edited by Rich Biebel; 08-20-2012 at 02:03 PM. |
Rich I didn't know you worked with Matt......knew it had to be difficult considering the circumstances.....you "guys" did a great job !!!!!!!!!!!!!!!!
Joe Franco SS176 |
Joe I am the guy Matt says infected him with drag racing...
He usually says that after losing in the first round somewhere....LOL
Liked 239 Times in 114 Posts
That is interesting about the coil wire. I had pulled the spark plug out , then reattached the spark plug wire, and I cranked it over. Thought the spark was a bit weak, might be the problem . Can you change the coil without removing the generator from the motorhome ? Thanks for the tip !
I learned everything I know about any and all Onan generators the HARD WAY.....and trust me the coil wire issue was one that beat me up before I found it....
The first time I found one of those I had the generator in and out twice in one day and worked on it all day while the owner waited.....and it was very hot out that day......The owner was traveling around the USA and living in the M-H......A Florida retiree.... No you can't change the coil without removing the generator from the M-H if it has that type coil.... The older ones had a little blue coil mounted to the left of the spark plug and it could be replaced but never goes bad... The newer style units mount the coil under the blower/flywheel The unit has to be diassembled just to get at the coil. The coil wire is integral to the coil and can't be changed seperately......It fractures at the sharp bend it has to make as it heads toward the spark plug.... It will show you a weak spark and once the unit starts it gets worse.....and usually will not stay running......
