Old 08-21-2012, 11:47 AM   #1
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Default Re: Spin Control Question
Originally Posted by CrateCamaro View Post
Does the car have drop spindles? I just quickly skimmed through the posts and a seen that you had not cut the springs but the nose of the car is way in the weeds. Measure from the fender to the floor at ride height and then jack it up and just before the wheels come of the ground take a measurement and tell us what you got.
Spindles are stock. Springs are Santhuff's lightest spring.
Travel measures about 7".
I lose lots of travel when I come up so high on the converter. Lower RPM means more travel but the light suffers.
Floaters on the rear and a box at the rear of the spring. The track on the box has a detent from the years of use. I've looked into making it a coil over with ladder bars or possibly a 4 link.
I've added 100 lbs in the trunk.
Ron Gusack is offline   Reply With Quote
Old 08-21-2012, 12:10 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,953 Times in 590 Posts
Get rid of the sliders on the back of the spring and put the shackles back on until you put the coil overs on. I had the same issue with the sliders on my car. As long as something is not bound up in the rear suspension the leaf springs will work just as good. I did not see any improvement in performance when I took the leafs off of my car and installed coil overs. There was a little weight savings though. It's all about the geometry on the ladder bar set up. Once you find the sweet spot your car will start working
Mike Pearson 2485 SS
Old 08-21-2012, 01:56 PM   #3
Ron Gusack
Ron Gusack's Avatar
Mike, I thought the slider helped keep the rear from binding. I have a lot of options to sort through. Ladder bar, 4 link, or Cal Tracs.
Old 08-21-2012, 02:46 PM   #4
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Cal-trac, cheapest , easy to work on, they can walk you through the prosess. There are many Nova's running them, just look at the pictures posted on this site.
Bob Pagano A/SA
Old 08-21-2012, 02:57 PM   #5
Ron Gusack
Ron Gusack's Avatar
If money was a non factor, would Ca'-tracs be your first choice?
Old 08-21-2012, 04:05 PM   #6
Bob Pagano
Bob Pagano's Avatar
Yes ! Just look, pictures abound all over the net, many bracket cars and Stockers run them. The reason ? they work. Add them and get your front end to work then hang on !
Bob Pagano A/SA
Old 08-21-2012, 07:04 PM   #7
Liked 1,907 Times in 427 Posts
With ladder bars and leaf springs, the rear end housing must be mounted in "floaters" in order for the leaf springs and ladder bars to work without binding.
If you do not have something like this : http://www.competitionengineering.co...?CatCode=10047
on your car, and you're running ladder bars and leaf springs, your rear suspension simply does not work.
Given the choice, I'd never bother with ladder bars again, ever. If I wanted full aftermarket rear suspension, it would be a four link with a wishbone locater and coil over shocks.
For a car like yours, if you do not intend to go faster than 9.30 or so, and you want to run smaller tires, say 9" and 12" slicks, the by all means I'd put a complete Cal Tracs system under it, their leaf springs, their bars, their mounts, and their shocks.
Sure, full aftermarket suspension is the ultimate, if it is allowed, and you're going really quick, it's the thing to have.
But you're running in the mid nines, and you're running 9" tire classes at times. I would not go to the expense of a four link for that.
