Old 08-30-2012, 12:54 PM   #1
philbilly
philbilly's Avatar
Default Re: My 283 Build
lifters is the next thing on the list. Whats availble?Is there any way to check mine to see if they are hurt? I know the cam co. has lifters? is there advantage to shubecs or what ever they are ?
philbilly is offline   Reply With Quote
Old 08-30-2012, 02:00 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
shubeck now smith lifters have diamond hard bottoms (some kind ceramic)on them can run more spring pressure don't have to break-in and can be used on another cam they are somewhere around 750.00 Precision perf. products in NC. have tool steel made for NHRA are around 475.00 can use about 425lbs max spring pressure.
You can check lifters with straight edge hold up to light should see lifter crowned in center if check with dial indicator center needs at least .001 crown in center
If you had bearing trouble cam and lifters could have material embedded and will eat lobes up fast can send in and have refinished and redo the parkerize(the black finish on lobes)
Also Smith's and PPPC lifters have extra travel removed plungers just move .015 mininium allowed
Mike Taylor3601
Old 09-21-2012, 08:14 PM   #3
philbilly
philbilly's Avatar
Well I finally finished the 283 up. I got one run today at national trail. 12.23 at 107. I want to thank everyone involved in getting me back together. You know who you are.
Old 09-22-2012, 06:23 AM   #4
69Cobra
Liked 2 Times in 2 Posts
Looks like you've picked up a few tenth since BG. NICE!!!!
Happy Birthday today Phil and I hope you bring home the win in C-Bus.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 09-22-2012, 01:19 PM   #5
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: My 283 Build
Good for you Phil! Glad to see you are back together and doing well! Jim
Old 09-22-2012, 03:01 PM   #6
TinSoldier 3215
Liked 6 Times in 5 Posts
PhilBob!! Take that motor to Tony and be DONE WITH IT!!! What would WADE TELL YOU???
TinSoldier 3215 is offline   Reply With Quote
