Old 09-09-2012, 06:37 PM   #91
SSDiv6
Liked 1,583 Times in 582 Posts
Default Re: The damage recently done
Originally Posted by dwydendorf View Post
Isn't it amazing that the guys that are complaining the most, are GM guys and it is them who have been the benefactors of probably more rule changes and superseded parts as anyone. Remember unported heads and no combustion mods in Super Stock? It was the small block Chevy racers that pushed the rules as much as, if not more than anyone to get the head rules in Super Stock changed. Remember when Bowtie blocks with siamesed Cylinders were legal before anyone else could use a siamesed block? How about 327 intakes on 283's or how the small block Chevys were mysteriously allowed 550 gram connecting rods when the old spec was 570 grams? I am not an AMC racer but I think it is about time that they were allowed some enhancements that some of the other brands have been allowed. After all, isn't the AHFS supposed to take care of any runaway combinations? This is pure speculation on my part, but just maybe the NHRA tech department has gotten tired of all the GM guys complaining about every little thing and decided to really give you guys something to complain about. Or maybe the tech guys thought it would be nice to see something other than Camaros in Stock and Super Stock. Hey GM guys, keep complaining because it is helping the AMC's,Mopars and Fords and we need more of those brands in Stock and Super Stock.
That is just the tip of the iceberg...
Let's add the enhancements on cylinder heads, pistons and cams that have taken place; they all mostly started with GM cars.
I believe if the rules allows enhancements for one make, they should be the same for other makes.
So to Billy and Paul...
Do you believe it is okay to allow the 1962 Plymouth 383/343 HP with over the counter parts that adds two 4;BBL's, cylinder heads with bigger valves a a different cam compete and not do so with the AMC's with the same approach minus the cylinder heads???
Old 09-09-2012, 08:14 PM   #92
Crew Chief
Liked 10 Times in 6 Posts
...Do you believe it is okay to allow the 1962 Plymouth 383/343 HP with over the counter parts that adds two 4;BBL's, cylinder heads with bigger valves a a different cam compete and not do so with the AMC's with the same approach minus the cylinder heads???
The 62 Plymouth 383/343 was accepted by the tech dept in 1962 and has been allowed since 1962.
The AMC over the counter modification parts were not accepted until just recently by someone. That means it must have been turned down by the tech dept in the late 60's and has been denied for several decades.
In recent years several non-stock, bolt-on, across the counter modification parts that are only listed in OEM accessory catalogs have been added which is in direct contridiction to the rulebook. Maybe whoever is accepting this stuff needs to be reminded of what their own rulebook states for Stock class!
"Section 10A, page 3 ENGINE: Must be same make and year as car used, aftermarket NHRA-accepted cylinder blocks permitted. Equipment other than original factory-installed prohibited. Any special equipment export-kit (superchargers, dealer-installed options, etc.) automatically disqualifies car."
Wanna bet that rule gets deleted for next year?
Maybe it will be changed to..."Across the counter parts listed in accessory catalogs by the OEM for bolt-on modifications will now be accepted no matter how long ago the catalog was printed or how many times the original tech dept turned the parts down."
Crew Chief is offline   Reply With Quote
Old 09-09-2012, 08:26 PM   #93
Liked 5,121 Times in 1,952 Posts
Not anymore...since 2009
Old 09-09-2012, 08:28 PM   #94
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
I know you're talking to the other Paul but I'll add my 2 cents. The 383/343 had a different HP factor that was about right where as the single four early 383s were never competitive until the HP was finally dropped in the 2Ks. The cam, 445 compared to 430 lift means very little as the 445 lift lost 25 thousandths or so to the lash for the solid lifters. The manifold for the 343 hp wasn't some new high tech mani, it first appeared in late 1957, mine is dated 10-57, they were first used on the 58 Furys with the dual quad 350 like in the movie Christine. The larger exhaust valve is almost meaningless in performance. Allowing a Holley 3310 which flows 800CFM over a 600 CFM carb in today's Stock or Super Stock without changing the HP factor is quite a gift, I have 343 AMCs on my mind right now. 67 Marlin in the 10s in stock, it could happen in the right hands.
Old 09-09-2012, 08:43 PM   #95
noel t davis
Can't figure out all the complaining. As long as you're putting shoe polish on the window what does it matter. I am not a naive newcomer either, have been racing stock,super stock, and comp starting in 1966. Nhra 325 stk,ss,comp.
noel t davis is offline   Reply With Quote
Old 09-09-2012, 08:44 PM   #96
SSDiv6
Like Dwydendorf commented; the rules seems to have preference on certain car makes and are not applied consistently across the board.
Let's take an example as to "Dealer Installed Options"; how did the Saleen and Roush cars got in the books?
There are so many items such as options and modified parts that have been allowed in the books and suddenly everyone is up on arms and get their shorts all wadded up when AMC's get some allowances like other makes!
We can all point to how many things NHRA has allowed throughout the years. Another example is when they allowed automatic transmissions in the 1967 Galaxie 427 with two 4BBL's; they were a stick car only from the factory. When I asked NHRA about it, they said since an automatic trans was available in the Galaxie model, they allowed it although it was not available with the engine.
Another example was many years ago when a friend was thinking of running Stock Eliminator with a 396/375 HP Chevy. He buys a set of OEM pistons and also the replacement TRW pistons. Purchases the latest Lunati stocker cam and calls me because all his valves were hitting the piston dome. I check the engine and there was no way the cam would clear the pistons. I make a few calls and find out about the machining and massaging of the valve reliefs and later on the glass beading to hide the mods to make the cam work. He choose to just bracket race in lieu of modifying his pistons. Therefore, could we assume the pistons were modified prior to submission to NHRA for approval?
..and the list goes on...
Old 09-09-2012, 09:03 PM   #97
Todd Hoven
Guest
Posts: n/a
We still race HEADS UP WHEN MEETING A CAR IN THE SAME CLASS. This is not Pro ET. If a car get an advantage with superceeded parts with no HP increase, it decreases the other guy's chance to win these types of races. Im sure the same thing would happen in 1966
Old 09-09-2012, 09:46 PM   #98
SSDiv6
The old days of Farmer's oversight are long gone!
NHRA lost control of tech many years ago with the buddy system, their decisions by the higher ups overriding tech inspector decisions, lawsuits threats from racers, pressure from manufacturer's and sponsors and much more that has transpired.
So in a nutshell, the way I see it is if NHRA puts it in the books and approves it, then they deemed it good.
The only time I have seen NHRA remove a car combination was when they banned Bob Dennis from running the Oldsmobile with the 260/4-BBL QJ carburetor. Although it had been in the books for many years and the option was available in the export versions of the car, it still got pulled from the books.
Old 09-09-2012, 10:42 PM   #99
Jack McCarthy
Liked 476 Times in 117 Posts
Exclamation Re: The damage recently done
can i just get the 459 intake i am the ONLY 283 in the world who cannot run it ???
please ... jeff who do i call ???
captain jack
its just a big joke anymore race now we will be gone soon .
Jack McCarthy 3609 STK
"the Captain"
Jack McCarthy is offline   Reply With Quote
Old 09-09-2012, 11:09 PM   #100
Joe Toller
Liked 4 Times in 4 Posts
WOW! I get off the computer awhile to go work on a car and see all this!? Glad I'm messing with something that should never be affected by this, although I still have to wait on a HP change before I get real deep in things...
BTW, out west here, the yards are full of old iron and parts, even AMC's. I'd be glad to point out a few places...69 Rebel 4dr/290 anyone?
But I am still building a 6 cylinder dime rocket (thanks for the help Billy), and this issue will pass I am sure.
Wanna see some crying? Build a big-dollar demolition derby car! They perfected it!
