#91 | |
Let's add the enhancements on cylinder heads, pistons and cams that have taken place; they all mostly started with GM cars. I believe if the rules allows enhancements for one make, they should be the same for other makes. So to Billy and Paul... Do you believe it is okay to allow the 1962 Plymouth 383/343 HP with over the counter parts that adds two 4;BBL's, cylinder heads with bigger valves a a different cam compete and not do so with the AMC's with the same approach minus the cylinder heads??? |
#92 | |
Liked 10 Times in 6 Posts
The AMC over the counter modification parts were not accepted until just recently by someone. That means it must have been turned down by the tech dept in the late 60's and has been denied for several decades. In recent years several non-stock, bolt-on, across the counter modification parts that are only listed in OEM accessory catalogs have been added which is in direct contridiction to the rulebook. Maybe whoever is accepting this stuff needs to be reminded of what their own rulebook states for Stock class! "Section 10A, page 3 ENGINE: Must be same make and year as car used, aftermarket NHRA-accepted cylinder blocks permitted. Equipment other than original factory-installed prohibited. Any special equipment export-kit (superchargers, dealer-installed options, etc.) automatically disqualifies car." Wanna bet that rule gets deleted for next year? Maybe it will be changed to..."Across the counter parts listed in accessory catalogs by the OEM for bolt-on modifications will now be accepted no matter how long ago the catalog was printed or how many times the original tech dept turned the parts down." |
#93 | |
#94 | |
Liked 327 Times in 121 Posts
#95 |
Can't figure out all the complaining. As long as you're putting shoe polish on the window what does it matter. I am not a naive newcomer either, have been racing stock,super stock, and comp starting in 1966. Nhra 325 stk,ss,comp.
#96 | |
Let's take an example as to "Dealer Installed Options"; how did the Saleen and Roush cars got in the books? There are so many items such as options and modified parts that have been allowed in the books and suddenly everyone is up on arms and get their shorts all wadded up when AMC's get some allowances like other makes! We can all point to how many things NHRA has allowed throughout the years. Another example is when they allowed automatic transmissions in the 1967 Galaxie 427 with two 4BBL's; they were a stick car only from the factory. When I asked NHRA about it, they said since an automatic trans was available in the Galaxie model, they allowed it although it was not available with the engine. Another example was many years ago when a friend was thinking of running Stock Eliminator with a 396/375 HP Chevy. He buys a set of OEM pistons and also the replacement TRW pistons. Purchases the latest Lunati stocker cam and calls me because all his valves were hitting the piston dome. I check the engine and there was no way the cam would clear the pistons. I make a few calls and find out about the machining and massaging of the valve reliefs and later on the glass beading to hide the mods to make the cam work. He choose to just bracket race in lieu of modifying his pistons. Therefore, could we assume the pistons were modified prior to submission to NHRA for approval? ..and the list goes on... |
#97 |
Guest
Posts: n/a
We still race HEADS UP WHEN MEETING A CAR IN THE SAME CLASS. This is not Pro ET. If a car get an advantage with superceeded parts with no HP increase, it decreases the other guy's chance to win these types of races. Im sure the same thing would happen in 1966
#98 | |
NHRA lost control of tech many years ago with the buddy system, their decisions by the higher ups overriding tech inspector decisions, lawsuits threats from racers, pressure from manufacturer's and sponsors and much more that has transpired. So in a nutshell, the way I see it is if NHRA puts it in the books and approves it, then they deemed it good. The only time I have seen NHRA remove a car combination was when they banned Bob Dennis from running the Oldsmobile with the 260/4-BBL QJ carburetor. Although it had been in the books for many years and the option was available in the export versions of the car, it still got pulled from the books. |
#99 |
Liked 477 Times in 117 Posts
can i just get the 459 intake i am the ONLY 283 in the world who cannot run it ???
please ... jeff who do i call ??? captain jack its just a big joke anymore race now we will be gone soon .
Jack McCarthy 3609 STK "the Captain" |
#100 |
Liked 4 Times in 4 Posts
WOW! I get off the computer awhile to go work on a car and see all this!? Glad I'm messing with something that should never be affected by this, although I still have to wait on a HP change before I get real deep in things...
BTW, out west here, the yards are full of old iron and parts, even AMC's. I'd be glad to point out a few places...69 Rebel 4dr/290 anyone? But I am still building a 6 cylinder dime rocket (thanks for the help Billy), and this issue will pass I am sure. Wanna see some crying? Build a big-dollar demolition derby car! They perfected it! |
