Liked 2,486 Times in 697 Posts
My boy SS Aspen when it run around 1.40 @ 60 and 6.80 @660
runs 10.75 @ 122. I did not see your Tire Height shown. Hope this help ......Not exactly apples to apples. 3420 Wt and 3 Speed with 340 CID. |
i also forgot to mention i leave at 4600 and shift at 6800 and it drops to 4800 on the shift...converter flashed at 5300 and is the same one that flashed 6200 in the superstocker.so that is one problem ..it has 14x32 HOOSIERS.....thanks for all your comments.
Danny Waters, Sr / 73 Duster "340" |
Liked 1,937 Times in 582 Posts
Danny,
I would say thats a pretty good 60 ft time given the combo that you have in the car. I would say you need more gear in the rear. 586. The 180 low is killing you. You need a 198 low gear. The heads are probably quite a bit bigger than the old super stock heads and thats why the converter is not flashing as high. The power range is higher with the aluminum heads. The weather will also effect the 60. Hot and humid the 60 will drop off. Pump up the tires where you get a little bit of spin. if that picks up the 60 and overall et than you need to make some changes
Mike Pearson 2485 SS |
#4 | |
that's what i was thinking Mickey..........
