Old 09-27-2012, 07:34 AM   #1
MrWendy'sJr
Liked 25 Times in 1 Post
Default Re: Converter Temp Effect on ET
What type of trans temp gauge is better, electrical or mechanical? And full sweep vs short sweep?
MrWendy'sJr is offline   Reply With Quote
Old 09-27-2012, 07:55 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Digital
Old 09-27-2012, 09:15 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
An electric gauge makes for easier transmission removal.
ss3011 is online now   Reply With Quote
Old 09-28-2012, 08:54 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 307 Times in 103 Posts
I drilled and tapped trans above pan where temp gauge came down through top of case into fluid in pan, you could pull gauge probe and not lose fluid,also had plug could be put in if trans was going to be tilted while removed or transported.
Mike Taylor3601
Old 09-28-2012, 09:44 AM   #5
Jim Kaekel
Liked 535 Times in 110 Posts
I've got a mechanical trans. temperature gauge mounted in-line on the pressure side of the cooling lines. I've got one of those extruded aluminum coolers mounted underneath the right floor pan with a Auto Meter temperature manifold to accept the gauge. Works great and don't have to mess with it during trans. changes.
Jim Kaekel 3836 STK
