Been running E85 for over a year now and had some experience with it. Had some carb problems until I got hooked up with Mark Sullens, he is the best, you can go to his website and get some valuable information on what temp to stage and tuning. E85 does not vaperize till 165 degrees, so you need to be that before you stage. There is alot more to it than just bolting on a E85 converted carb. most agree you don't need to run over 7 pounds of fuel pressure. I buy E85 locally, just be sure and check it with a tester so you know what you are getting. My local station changes content from E85 summer to E75 winter blend. I will buy enough to fill my 55 gallon drum in the summer when they have the true E85.
#2 | |
Liked 2 Times in 2 Posts
1969 camaro, pump gas 540"bbc, jerico 1967 camaro, pump gas efi 620", coan t-400 |
#3 | |
Liked 880 Times in 311 Posts
Do any of you know anyone that took an Alky carb and modified it for E-85?
I've got a small cu in (316) old Modified engine (short block). I've thought about putting in a bracket car and using E-85. The original heads are gone and the heads I have for it will keep the compression around the 12-1 mark. The carb is a 750 QF alky. Any ideas/suggestions?
Adger Smith (Former SS) |
Liked 2 Times in 1 Post
How due you manage the E85 corrosiveness? Or is not as bad as some people have perceived.
Bob |
Liked 10 Times in 1 Post
Methanol is corrosive . E-85 , which is ethanol , is not corrosive. Ive left it in the carb and the rest of the system all winter with no sign of a problem.
Billy Leber 1150 SS, 1050 SG, 1962 STK, 185 SC |
#7 | |
Careful with that statement as it made some of my plastic handles on my screwdrivers soft... For me I run my carb dry after i am done for the day and just before it starts to stall I spray engine stor down the carb |
#8 | |
Thinking you should be able to do it as you need to see what there is for emulsion and banjo's/boosters.. |
