Old 10-15-2012, 05:45 AM   #1
james schaechter
Liked 1,443 Times in 302 Posts
Default Re: Question for Jerico dr4 owners
The earlier model has narrower 3rd and 4th gears. They look similar to the casual observer, but many parts are hard to find. I would stay away from an early narrow gear as your main or only box.
Also, even if it is a newer wide gear box, make sure the input and ratios are what you want. It can get expensive changing stuff.
Yes, call Jerico and talk with Scott. If you can bring someone to look it over with you, better yet.
The only shifter to use is a Long Vertigate.
James Schaechter 3163 STK
Old 10-15-2012, 10:00 AM   #2
Run to Rund
Liked 56 Times in 29 Posts
The Hurst VGate2 is a re-label of the old Mr. Gasket Vertical gate and it works also--it looks like Long copied it. Be sure to use the stops, a removable, optional item for some years. Either the Ford top loader "kit" or the special Jerico kit (both from Hurst) should work for the rods. However, it can be hard to find a vertical gate these days; they have gotten so expensive on ebay that you might as well get the scienced out Long.
I believe there are road race hardened gears as well as the "softer" drag gears, meaning the W series Jericos wouldn't be suitable but are more readily available used because that is what Nascar racers used. Road race and drag sliders were available, with the former allowing easy downshifting but being less suitable for "serious drag racing" as Jerico put it.
