Old 10-29-2012, 02:03 PM   #1
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 319 Times in 108 Posts
Default Re: standard size rings in a .020 motor?
Std. rings in .020 bore would have about .070 extra end gap,as Adger said I say you solved that mystery. I explain to customers who are going to assemble their own engine check ring gap,bearing clearances on all rings(the whole set) all rod and mains,check cam timing even on stock engine,the more checking you do during assembly,the less trouble you'll have,find the problems during assembly,not when you start it up
Mike Taylor 3601
