#1 | |
Sponsor
Liked 63 Times in 11 Posts
![]() Assuming you run an alternator our 7lb 900 amp 16 volt lithium battery would easily handle your application. Visit our website or contact us for more info! Also click on the Altronics banner at the top of the forum for special discounts. |
A good quality battery is important but, when your car is running, all of your accecssories are running pretty much off of the alternator so, having an alternator with the correct amperage output is the first thing I would look at.
As far as a battery, we run the lightest replacement battery we could find (nothing fancy) with no problem. We are running almost the same accessories as you are.
Nelson Kowal Stock 345 |
What kind of amperage alternator is recommended for a 16v system? I suspect a 55 is probably the bare minimum for a typical S/SS car.
I have a Performance "V" 16v battery and need to buy an alternator. Long ago I did a running amp test on all components and as I recall, it was about 38 amps. I might go overkill with the idea that I don't have to charge the battery at all at the races. Any input on brand, size and amperage?
Jeff Lee 7494 D/S '70 AMX |
