Old 07-20-2007, 10:39 AM   #11
Mike Pearson
Mike Pearson's Avatar
Liked 1,956 Times in 591 Posts
Default Re: 62 Chevrolet, STILL No Traction
Make sure the lower link connecting the rear end to the frame is running down in the front at least 2 degrees. Park the car on a level surface and step back and look at it visually first. the bottom bar must run at a down angle ( lower in the front ) in relationship to the rocker panel. If it is running up it will not hook up even on the best track with new tires. You may need to adjust the ride height to correct this problem if it exists. Had the same problem with my super stocker.
Mike
Mike Pearson 2485 SS
