Old 07-20-2007, 11:59 AM   #11
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Default Re: 62 Chevrolet, STILL No Traction
Make sure the lower link connecting the rear end to the frame is running down in the front at least 2 degrees.the bottom bar must run at a down angle ( lower in the front ) in relationship to the rocker panel. If it is running up it will not hook up even on the best track with new tires. You may need to adjust the ride height to correct this problem if it exists.
Mike
that bears repeating
all said
THAT is exactly what I am experiencing... no traction, no matter WHERE the tire pressure is !
Mike, it would be basically impossible to make the lower control arm rake "down", while even remotely staying within the rules.
By lowering the car though, I can get a lot closer... and the upper arms will provide that snap down ( up on the body ) on the axle housing when it tries to rotate back under engagement.
Thank YOU, Mike !
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
