Old 11-17-2012, 04:45 PM   #1
69Cobra
Liked 2 Times in 2 Posts
Default Re: Rules amendments 2013
Good point, Rory
Kinda makes me wonder if these people installing the new seats are the same ones who can't possibly notch an OEM seat for a shifter, weld up a seat track mechanism so it won't move, strip down a seat and gusset the weak points, cut a slot through the back for a Y harness, secure the seat back against the roll bar brace so it can't move rearward or beef up the ORIGINAL mounting, if so needed?
Hey Mark,
Do you have an extra factory bench seat for a 69 Cobra laying around that you could donate to this cause? I'm not going to cut up and alter the ORIGINAL seat for this car. You guys are worried about people installing the aftermarket seats safely and correctly but you are recommending that I cut up and the factory seat frame to notch it for the shifter? Which will more than likely be a weak point in a crash?
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 11-17-2012, 06:58 PM   #2
Liked 5,125 Times in 1,953 Posts
Originally Posted by 69Cobra View Post
Hey Mark,
Kris, pretty sure you wouldn't have had to use an original Cobra seat, the way the rules were.
...and as far as the notching...That all depends on who's doing it...same as the mounting of the new seats or seat , singular . I guess you don't even need matching style front seats any more...Just like Bracket II.
Old 11-17-2012, 08:28 PM   #3
Tony Janes
Not quite like bracket 2 but close. You still have an index to work from.
Tony Janes 7941 STK, SS
Old 11-18-2012, 12:39 AM   #4
Todd Hoven
Guest
Posts: n/a
And don't forget heads up and qualifying. Plus most cars at a bracket race have the technology of cement mixers.
The seat thing is done, like it or not. The interiors of the cars will not look as cool, but will be much safer. It's real simple, if you don't want to change don't. I'll take the 60 pound savings, that should make that pill a little easier to swallow for me.
These rules are changing, whether we like it or not
Old 11-18-2012, 12:58 AM   #5
Todd Hoven
Guest
Posts: n/a
Delete
Old 11-18-2012, 02:15 AM   #6
69Cobra
That's a good idea... maybe I run the Kirkey on the driver side and a Jazz on the passenger side... Just like Bracket II
Kris Rachford
C/S 3032
Old 11-18-2012, 09:23 AM   #7
Crew Chief
Liked 10 Times in 6 Posts
..... I guess you don't even need matching style front seats any more...Just like Bracket II.
WRONG!!!!!! Both seats have to match. Just ask the S/S guys who tried to get away with a minature Kirkey on the passenger side.
Crew Chief is offline   Reply With Quote
Old 11-18-2012, 12:35 PM   #8
ken robinson
Liked 222 Times in 87 Posts
I think the seat rule grand fathers in all the new cars ( because those cars in the show room dont gots aftermarket seats ) and its an added safety thing . I did get a chance to sit in some of the newer cars with the newer seats and they are nice . I am not sure how the copo seats would look in a 67 camaro ? The 3speed rule is only for the glide replacement , I dont think you can swap a 3 speed auto in a car that had 4speed stick only as was asked about earlier . Hey Bob you if you put front seats in the wagon you can just run N/sa .....lol....
Old 11-18-2012, 02:00 PM   #9
Dan Wilson
NHRA will put a date on these seats and make you change them every 2 years!!!!!!
Dan Wilson, STK3171, K/SA
Dan Wilson is offline   Reply With Quote
Old 11-18-2012, 02:12 PM   #10
Liked 10,731 Times in 2,233 Posts
Dan you just spoiled the NHRA surprise Christmas enhancement.
