Old 12-05-2012, 08:04 AM   #8
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default Re: 84 Olds Cutlass Motor
If the blueprint specs. call for a dished piston (and I'm sure they do), then it has to be dished piston. No if's, and's or buts.
Are you sure the motor you're looking at is a flat top motor? Because a '82 - '84 Camaro 150 HP is a dished piston motor.
If you have questions, don't be afraid to ask. That's the 0nly way you will learn. Not everyone here is a wise guy.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
