Old 12-08-2012, 09:37 AM   #1
art leong
Default Re: Autolite double platinum plugs? Also indexing?
Art, what is the part number of your current plugs?
The plugs I've been using are Brisk RR12S The stock plug would be a Champion 470.
The plug I'm going to try is an Autolite APP5263.
My cylinder head is from a 2000 PT Cruiser.
Ed I've heard the same thing about the extended plug and the timing. I'll take some out before running it. I ran more timing than other comparable neons. Could have been the retracted tip.
Art Leong 2095 SS
Old 12-08-2012, 02:02 PM   #2
art leong
Here are some pics of the plugs
Brisk RR12S on left, Champion 470 (stock) center Autolite APP5263 on right.
Brisk plug in head
Autolite plug in head
Art Leong 2095 SS
Old 12-09-2012, 01:11 AM   #3
SSDiv6
Art,
I would recommend the following Autolite Racing plug numbers:
AR3932X or AR3933X
The AR3932X is a colder plug.
Old 12-09-2012, 09:58 AM   #4
art leong
Art,
AR3932X or AR3933X
Are those 25mm (1") reach with a tapered seat and 5/8 (16mm) hex?
Those are the parameters I need
Art Leong 2095 SS
Old 12-09-2012, 05:51 PM   #5
SSDiv6
The specifications show the lengths as follows:
The Champion 470 is 25.5mm (1.00") long.
The Autolite AR3932X is 25mm (0.984) long.
The Autolite plug is also shown as a plug application for the late model Hemi engine.
It may not require adding the washers as you want to.
Old 12-09-2012, 07:47 PM   #6
quickford1
Liked 20 Times in 12 Posts
The Autolite X plug shown is 3/4 reach gasket seat, They do make a .708 tapered seat X plug I have all of the X plugs in stock.
Rich
quickford1 is offline   Reply With Quote
Old 12-09-2012, 08:00 PM   #7
Jeff Lee
Jeff Lee's Avatar
What's the story on the X plugs? Any performance gains? What is the target market?
Jeff Lee 7494 D/S '70 AMX
Old 12-10-2012, 01:06 AM   #8
SSDiv6
Art,
It double checked and the above plug is incorrect.
The confusion stems from your statement for a plug for a 2000 PT Cruiser cylinder head. The PT Cruiser was launched in 2000 as a 2001 model.
So, for a 2000 Neon application, the spark plug is not tapered, it uses a gasket and the above racing plug will work.
You should look at the tapered plug that Rich (quickford1) has available.
Old 12-11-2012, 10:48 AM   #9
quickford1
To try to answer everybody at once I will try to explain the X plug. It was first used in Nascar because of ground straps burning off or breaking off, they are made by both Autolite& Champion in limited heat ranges and numbers .They are used by just about every team. They are available 708 tapered seat & 3/4 reach gasket seat. The best part is no need to index. These plugs are made in limited runs so are hard to get sometimes.
Rich
