#271 |
Liked 174 Times in 39 Posts
Well they would factor that down to 330 like the 70 because its the exact same motor. They just put it in a corvette a year earlier than a camaro.
3207 D/SA, C/ED |
#272 |
actually i believe it has a holley instead of a q-jet
Chad Rhodes 2113 I/SA |
#273 |
So does the 70 LT-1
3207 D/SA, C/ED |
#274 |
so 71 was the change, my bad. it does show a 485/485 camshaft in the 69 though. Different carb numbers but the specs are the same for them.
Chad Rhodes 2113 I/SA Last edited by Chad Rhodes; 12-08-2012 at 02:38 PM. |
#275 |
Yep, the only difference in the 69 vs 70 is the 485/485 vs 458/485 cam. The 71 moves to a different head and a flat top piston and is rated at 315 in both the Camaro and Corvette.
3207 D/SA, C/ED |
#276 |
Liked 279 Times in 68 Posts
71 and 72 also have a Holley, just less compression and different heads.
Greg Hill 4171 STK |
#277 |
Liked 4 Times in 4 Posts
Gentlemen,
Using my fading memory and wikipedia I find that the LT1 was only manufactured in 1970-72, no mention of production in 1969. The closest HP 350 I could find was the L79 350/350 anything with higher HP was a big block. I've been wrong before, well not really, OK only three times and I'm finished paying alimony, if you could direct me to a site that gives the spec's for the 1969 LT1 I would appreciate it. JimR
Jim Rountree |
#278 |
Don't give me any crap about our motors. Who's got the school bus motor that now has a cj cam, aluminum intake, and a 780 Holley carburetor. I remember those 390's in the 60's and they wouldn't out run a 327 Camaro. Plus you're building one of the bogus crate motors so you'll be a half a second in front of me and Andrew.
#279 |
Haha, can't tell it's the offseason already....
I got a strange idea that I think might end up working over time in getting these new cars where they should be. Keep the pedal to the floor? ![]() |
#280 |
Liked 520 Times in 132 Posts
Most guys redo their stuff on a yearly basis , bigger cam's, more cc's, bigger valves, higher compression , bigger carbs is easy stuff to do .
Bo most of us don't have a wheel barrel full of cash to spend on our race cars. In my case being a State Trooper doesn't allow me to upgrade my engine every year as you suggest.
