Liked 520 Times in 132 Posts
Where can I get a 4GC air cleaner base like this? Thanks
Liked 354 Times in 120 Posts
If that one is off of normans car it was fab up by patterson. If you look it is two pieces put together. If I remember right if you get a quadrajet from a pontiac then adapt it to the 4gc opening. Tom
Tom Meyer 5240 SS Stock ??? |
Liked 285 Times in 87 Posts
Ed... That is the standard base from an OEM open element HP air filter assembly. It came on Quadrajet and Holley performance applications 1966-69. Someone has done a clean job of making it work with the 4GC, adapter ring and fuel inlet tube. You most likely will have to make your own from the picture. If you need a base, try Corvette Central or Classic Industries. I hope this helps.
Liked 510 Times in 117 Posts
68 Chevy11 327 F/S |
Liked 68 Times in 41 Posts
All I know is that if it not a factory air cleaner base,it can not be higher than the choke horn (meaning if you put a strait edge cross it,the choke horn has to hit it.) had to take it off in the 4th round after they saw it when I was getting fuel checked, another UN-written rule,that was in stock
for super stock AIR CLEANERS Optional. If used, air cleaner must be OEM automotive or retain OEM configuration. Air-cleaner base may be cut or trimmed, but welding, bolting, riveting, epoxying, or any other form of fabrication prohibited. Ram tubes, velocity stacks, or other than stock-type base plates or ducting prohibited. Cooling holes prohibited in radiator side panels, etc. Factory air cleaners and/or scoops that fit through hood must be affixed to carburetor as per OEM only.
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay Last edited by dartman; 11-29-2012 at 10:13 AM. |
EBAY....item # 230835819406
It is a modified one of these...... D L Rambo......Stk 1300 |
Thanks I appreciate it.
Try this one : ebay # 130821984840
What is particularly appealing about this base?
Ed |
Was worth a couple hundredths on my old 250 HP 327" '65 Chevelle convert.
Ed Wright 4156 SS/JA |
