Liked 138 Times in 51 Posts
As mentioned, it is allowed. But aside from the advantage of easier to find neutral/internally balanced dampers flexplates and converters, I was always told that internally balanced assemblies are easier on the crank and bearings. It's probably more relevant to higher rpm combos, but something to consider nonetheless.
ok thanks for the info
Liked 14 Times in 11 Posts
You can also take a externally balanced motor (such as a 360 SB) and have
it internally balanced (does use more heavy metal). But it can be done.
Phil Saran Parker, Colorado |
