Old 01-13-2013, 08:00 PM   #1
FED 387
Liked 333 Times in 180 Posts
Default looking for a low tem mechanical oil temp gauge
need a low temp (starts at 100*) and goes up to maybe 240 or so mainly looking for a full sweep gauge that has most of the degree readings below 180 not one of those that goes from say 100 right up to 140 then has most of the readings in the upper range---any one have any ideas ??
Old 01-13-2013, 08:53 PM   #2
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
Default Re: looking for a low tem mechanical oil temp gauge
autometer makes a 2" gauge that starts out at 120 degrees gmonde
Old 01-13-2013, 10:10 PM   #3
P Bailey
Jegs has a temp guage that goes from 100 to 280. Their part #is 555-41202. Good luck. Phil
P Bailey is offline   Reply With Quote
Old 01-13-2013, 10:11 PM   #4
Bob Gullett
Bob Gullett's Avatar
Liked 510 Times in 117 Posts
Just use a water temp guage. Its the same guage. Only difference on the guage is the lettering.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 01-13-2013, 10:18 PM   #5
gmonde
gmonde's Avatar
here is the gauge that I have gmonde
Auto Meter Ultra-Lite Analog Gauges 4332
Old 01-13-2013, 11:42 PM   #6
FED 387
looked at both of those gauges - not what I'm looking for-I want a gauge that has more measurements in the 100-200 range do not care about those numbers over 220-280-looked at SW/Autometer/Sun/Sunpro/Marshall still do not see one --But thanx for all those ideas will keep looking
Old 01-13-2013, 11:50 PM   #7
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
I am sure its not what your looking for but an electric, or digital may be the only way to get that range, and be accurate.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
Old 01-14-2013, 08:58 AM   #8
Ed Wright
Ed Wright's Avatar
I had to get a digital for my coolant. Same gauge for oil. It's a Dakota Digital. Goes to 70 degrees F. Below 70 it just says "Low". Goes up in 2 degree increments.
I just leave the chiller on 'till it says "Low". LOL
No reason it would not be fine for oil. Needs 1/4" npt hole.
Ed Wright 4156 SS/JA
Old 01-14-2013, 01:49 PM   #9
Paul Merolla
Paul Merolla's Avatar
Liked 293 Times in 65 Posts
I had the same issue but I ended up with this: http://www.summitracing.com/parts/atm-4369
It's 60-210 degrees.
Paul Merolla is offline   Reply With Quote
Old 01-14-2013, 03:15 PM   #10
FED 387
Paul ---that's what I need wonder if they have a mechanical one
