1962 Chevrolet 327 out of an impala ss. looks to be untouched .
When your trying to sell it you have to say it came out of a Vette. ---Trevor
Liked 308 Times in 103 Posts
Also that it does'nt use a drop of oil, or if you have'nt ran it since you've owned it you could say it has'nt used a drop of oil since I've owned it.LOL
Now on serious side I don't really know a # to tell you. Mike Taylor 3601 |
Liked 783 Times in 195 Posts
If it is a 300 hp version, it could have 461X heads which would up the ante a bit. Hemmings is a good place to sell such stuff.
Liked 719 Times in 220 Posts
What version of 327 is it? A 250 horse has a 4 jet carb, the skinny intake, #520 or #896 heads,(power packs with the little pyramid), and exhaust manifolds with a 2" outlet. The 327 has an AFB, the wide intake( #459) . and a set if 461 camel hump heads .They also had the 2 1/2" exhaust pipes like a 409 had. Should bring a few hundred bucks at least. Good find!
The numbers from the deck are,CEN9809 The Heads 896, Block Is 3989612 . I'm Not trying to sell the Engine, Just Trying to Figure out If I should Keep it Around. Thanks For The Replys
Liked 166 Times in 46 Posts
Those things are getting hard to find, I'd hang onto it.
If that's an original never rebuilt complete take out engine, it's probably worth around $650-1000 depending on condition, but only if it still has an original standard block and crank. Those are almost made of unobtanium.Also, with an 896 head, it's a 250 horse. Might be a good Stock Eliminator piece with a #459 intake and a 4 jet.What happened to the 62 Chevy?
Last year I bought a complete 1968 327-250hp engine that had been pulled out of a wrecked '68 Caprice 20 years ago. It was from the air cleaner to the pan, flex plate to the fan, for $250.00.
IHRA STK 932 O/SA |
62 Impala is alive and well . the owner wanted a crate motor with more power.
