Liked 216 Times in 77 Posts
I have had very good luck with the Craftsman Alum. Jacks. Not the cheap on they sell the more expensive one. I have one in the shop, one on my service truck, and one in the race trailer. Not one problem out of any of them. The one in the trailer has lived a easy life. The other two have had it pretty rough and still keep going.
#2 | |
Liked 275 Times in 76 Posts
I have not had the same luck with the Craftsman Alum jack. I found out the hard way that the same warranty for hand tools does not apply to their floor jack. Just past having for a year and it stopped lifting 100% of max height. Not sure if it is made anymore, but supposedly not rebuildable. This is the one I have. http://community.craftsman.com/Craft...--2783-reviews
Liked 1,840 Times in 428 Posts
Ron go with the Harbor Freight jack.I have the aluminum Craftsman..also ..HF is better and cheaper..Got any more chicken.?
james perrone 1290 STK |
#4 | |
Rob,
I am glad, My wife got it for me for Christmas a few years ago, and now it looks like the Harbor Freight Aluminum ones are made better, than that expensive POS. As for the Jack that I use at the track, it is the Harbor Freight 1.5 ton with a 3/4" piece of plywood with side rails to not allow the jack to roll off the plywood when not on solid ground, The plywood is not much bigger than the jack. Also use the plywood to place jack stands on, to lift the rear of car in the trailer.This prevents the jack stands from damaging the coin floor. Multipurpose tool! Sean
Liked 8 Times in 7 Posts
i'll tell ya right now, if it has cast parts, don't buy it....i'll post a pick of mine sometime...plus don't buy one with the single wide roller on the front, they don't turn worth a sh.........
without losers,winning means nothing. |
Liked 269 Times in 99 Posts
Have the HF 2 ton lightweight which is OK but they have a 3 ton which looks much more well designed.
http://www.harborfreight.com/aluminu...ons-68052.html This motorcycle jack is great for transmissions when working with jack stands on the floor!!! http://www.harborfreight.com/lightwe...ift-94715.html
Do the HF aliminium jack ,harder to pump than more common steel jack?
Liked 317 Times in 103 Posts
Thank you everybody for your input, I chose the HF 2 ton jack. It is bigger than my non working Craftsman 3 ton jack, but lighter. The two individual front wheels make it easy to turn vs the single roller bar version of the HF 3 ton.
Do not like the sensitiveness of it though, will not allow you to lower with very small increments or minor bleed. Wants to let go quickly as in it's ability to raise quickly. Again, thanks everyone. Ron Ortiz U/SA not jacking anyone around
Ron Ortiz 2102 STK |
