Guest
Posts: n/a
That's what I came up with Chris after plotting it all out two years ago. The front spring section has to be part of the equasion leaving the rear section as a spring. If it were solid I would say it is a slapper/ladder bar.
#2 | |
Liked 5,124 Times in 1,953 Posts
If I might clarify, I see the Cal-trac as a sophisticated form of a slapper bar, better able to control spring wrap up..thereby acting as a ladder bar.
#3 | |
Guest
Posts: n/a
Trivia: Competition Engineering made the "slide-a-link" back in 1972 or so. A friend of mine has them on his '72 Demon 340 G/S (?) that hasn't changed since he built it from a new car in 1972. Based on that, I'm under the impression John Calvert borrowed the concept and improved on it by eliminating the soft spot in the middle of the bar.
Which begs the question; which version is better? Personally, I see no use for the urethane shock absorber in the middle of the bar. But I see there are some real fans of the design. It would be an interesting test on the same car. Anybody here try testing the two?
Jeff Lee 7494 D/S '70 AMX |
#5 | |
That would be an interesting test. I do know of one racer who switched for the slide a link to the Cal tracs and saw a major improvement. I think the difference between the two is the slide a link will work with a steel multi leaf spring, where a Cal Trac works best with a mono leaf. From what I've seen, I'm yet to see a car with multi leaf srpings work like one with a mono leaf when using the Cal Trac set up. But I've seen some good working cars using Slide a links and multi leaf springs. George (still using SS springs) |
Liked 2,336 Times in 464 Posts
Jeff the opposite is true. Cal Tracs came before slide o link. I had gone threw Moroso when they were designing the slide o link. Guess what was lying on the table. Are you sure your friend didn't have the Steve Hanby set up. Barry
#7 | |
I'm pretty sure the Cal-Trac bars came after 1982. Not trying to take away anything from John Calvert because as I mentioned, he improved on the concept, took it to a whole 'nother level and I'm sure his accountant is very happy with the results! And I think the split leaf is pure genius. He built a great system. I have the bars, springs and wheelie bar going on my car.
#8 | |
Liked 55 Times in 17 Posts
1967 Fairlane A/Stick - 1994 Mustang GT. 1989 Oldsmobile, R/SA - 2016 Z06 Weekend Street Car. |
#9 | |
Semantics aside, I'd say they constitute one link, all inclusive. The "missing link" would have to be above the axle center line on the housing to function like a true 4 link.
