Old 02-10-2013, 12:50 PM   #1
Frank Castros
Default Crankcase Ventilation
Any thoughts on this subject for Stock Eliminator applications?
Old 02-10-2013, 02:15 PM   #2
randy wilson
Liked 22 Times in 22 Posts
Default Re: Crankcase Ventilation
Ya, put a dry sump, and vac pump on. Just don't get caught. No, seriously, someone who actually knows the answer will chime in.
don,t have one
Old 02-10-2013, 02:41 PM   #3
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Good ring and valve cover seal with a sealed crankcase breather, and its worth it on my car. There is a thread about vacuum check valves, that is worth searching for.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Last edited by Sean Marconette; 02-10-2013 at 02:43 PM. Reason: Better explanation
Old 02-10-2013, 03:55 PM   #4
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
I can only pull a vacuum in the crankcase by using manifold vacuum. When things are right, I can get about 6" of negative pressure. If I just use the headers, I get no movement on my vacuum gauge. I recently discovered that my oil separator breathers weren't getting all the oil out of the vacuum line to the carb. I could see some oil residue on the carb gasket under the carb (see picture 2). I'm hoping a vacuum pump style separator will cure the problem. I use the old Jenkins/Moroso pan evac system. Does anybody still use this system?
[IMG][/IMG]
[IMG][/IMG]
Ron Gusack is offline   Reply With Quote
Old 02-10-2013, 07:42 PM   #5
Frank Castros
I've seen engines with a shop rag taped around the valve cover breather tube. What's up with that?
Old 02-10-2013, 10:31 PM   #6
Ron Gusack
Ron Gusack's Avatar
Engines with lots of blow by build pressure in the crankcase and if there's enough, a mist of oil will be pushed out of the valve cover breather. The rag was supposed to catch the oil. I haven't seen that done for many years.
Old 02-10-2013, 11:49 PM   #7
eddie c
I played around with a vacuum balance system on my stocker back
in 1975. Bill Jenkins was experimenting with it and the guys at SRD
who were neighbors ,were selling some of the components to make
systems. I still have some of the origional parts that I got from SRD.
I ran a vbs for a short time ,but I never really gave it a good test.In theory
they are supposed to improve H.P. ed
eddie c is offline   Reply With Quote
Old 02-11-2013, 12:47 PM   #8
Frank Castros
How about the use of PCV Valves?
Old 02-11-2013, 03:01 PM   #9
I assume you meant Super Stock? Stock Elim. was very restrictive back in '75.
I doubt you would have gotten away with anything more than an OEM type PCV back then..
Unless you were just using a Stocker for testing purposes ?
Old 02-11-2013, 04:25 PM   #10
Frank Castros
What I'm personally attempting to gain and learn from my initial question, having very limited knowledge of the subject in general and it's application to Stock Eliminator rules is, what is the current set up for the heavy hitters?
Also why does N.H.R.A. not allow valve cover breathers to be evacuated into the header collectors in Stock?
