Old 02-12-2013, 08:30 AM   #1
eddie c
Default Re: Crankcase Ventilation
Originally Posted by FED 387 View Post
Late 60's-early 70's GM Power brake check valve on the valve cover & then hose to the intake manifold and DO NOT forget to turn the main seals around!!!-- FED 387
Yes, That was another trick,You were supposed to run the front crank seal backwards and also, if possible, turn around your rear main seal.
ed
eddie c is offline   Reply With Quote
Old 02-12-2013, 11:04 AM   #2
eddie c
Originally Posted by BowtieFroggie View Post
That the turned around rear main seal was a Manley deal when the had the pistons with the rubber o-ring as part of the oil ring
Yes, yes it's all comming back to me now ! Was that for the single ring piston that was being experimented with. I believe one of my friends went to a Manley seminar back then and thought this new style ring ,piston combination was going to be " to die for" ed
Old 02-14-2013, 09:58 AM   #3
Bobby DiDomenico
Liked 101 Times in 52 Posts
ed
Can you actually pull enough where the seals would become an air leak?
I was guessing this is mostly extra carburetor cfm, just not using hollow bolts n things.
