Liked 3 Times in 1 Post
I have tried several theories at the track and confirmed some of them on the dyno. Brake booster valves are not created equal. There is dyno proven power here if you work for it. Mine will suck the bottom of the pan up against the pickup. You have to "release" the vacuum for the oil to drain. Then you'll know your close!
Wade |
Liked 780 Times in 194 Posts
#3 | |
Wade,
Please expand on your comment of "releasing the vacuum for the oil to drain". Quote:
#4 | |
Also, be very careful while playing with this, it does affect the oil pressure. If you use thin oil and low oil pressure, it messes with the bypass valve in the pump. Wade |
Wade,
Thanks, that's a great story, and it seems that you have found the system that works for you. This is a subject that merits serious consideration. |
I've spent a lot of money on PCV valves; trying different applications that I wont go into detail on. But yes, some work, some work better than others..and some don't work.
Jeff Lee 7494 D/S '70 AMX |
#7 | |
not being a hydraulic engineer or anything like it, but don't pumps need a certain amount of atmosphere pressure to pump? brake booster check valve and a sealed crankcase, sounds interesting. Use the manifold vacuum to pump the crankcase down.
67 Ford Fairlane F/SA 749 |
Liked 333 Times in 180 Posts
believe it or not if they are set up right ya can actually hear the air hissing a little(of course with the engine shut off) also pay close attn to any oil being sucked into the intake it will/could coat the top of the pistons and create detonation !!!
Liked 126 Times in 61 Posts
Back in the 70's we ran the single ring pistons in modified eliminator. The key was to have the engine sealed. Not having access to a vacuum pump we would take the vacuum off the running tow car to test the engine seal. We would try to have in maintain vacuum for one min. Today they make double lip crank seals we used O rings back then in the front and rear seals. We always had vacuum gauges in the cars. The system we used was the moroso setup on both headers as well as one going to the intake under the carb. We used the same mopar check valve that was used on the headers. If the motor was sealed you had small traces of oil in the intake after a run. With the oil separtors available today that should know longer be and issue.
Liked 138 Times in 51 Posts
I wish I would have had time to sit down & find out how he did it, but Truman Fields showed me his set-up on his 400 Firebird many years ago. Not sure if it was the IHRA Pure Stock or regular Stocker. Anyway, he told me to remove the oil fill cap with the car running. After tugging on several times with no success, I figured it was a twist-on style. After many turns, that didn't work either. Finally I grabbed onto it and gave it a pretty hefty tug, and it came out! He had an amazing amount of vacuum built up in the crankcase.
