Old 02-15-2013, 07:10 AM   #1
SCOTT TILLEY
Default Re: Back shocks
I have a '65 ChevyII I run in Super Stock Production with IHRA. It weighs 3030 with me in it. I use a 110 spring. Shocks are behind the rearend. I used a 95# spring for years. I thought maybe the shocks were bottoming out after talking with several racers on what spring I should be using. Turns out that I had no on track performance gain with the 110 spring. Same 60 foot of a 1.31-1.33 with a 327 2 bbl. I did notice the rear was much stiffer with the 110 riding through the pits.
Scott Tilley
IHRA SS/PDAII
SCOTT TILLEY is offline   Reply With Quote
Old 02-15-2013, 08:12 AM   #2
curtis reed
Liked 125 Times in 59 Posts
Here is a nice little spring rate guide from Afco. I would have the chassis shop scale the car if you haven't so you would know the actual weight on the rear.
http://static.speedwaymotors.com/ima...rts/AFCOIL.gif
curtis reed is offline   Reply With Quote
Old 02-17-2013, 09:42 AM   #3
Liked 10,763 Times in 2,237 Posts
Thanks Curtis, very good info.
