Just curious why your copper tubing is breaking. Do you have a loop close to the engines oil pressure fitting? I have had the same 1/8 " copper tubing on my Stocker for 10 years, and 3/16" copper tubing on my bracket car for 25 years, never had a crack, leak, or any other issue.
I don't trust copper or plastic tubing. I always use -4 braided hose.
Ed Wright 4156 SS/JA |
thanks for the responses
dont know why it comes out of fitting up motor thru firewall but i think i will find fittings to replace with #4 braided line thanks again |
#4 | |
Liked 888 Times in 239 Posts
that way I can use a short hose from the engine to the firewall and disconnect it at the firewall . Makes it a lot easier than disconnecting at the engine on some cars.
that's a great idea tom. i just struggled with tightening the nut on my fitting at the rear of the block. i am going to use this suggestion. will be WAY easier
That's how I do it. I have a 90 deg hose end under the hood, at the firewall. I put the engine in with that short hose connected to the engine. When you get old and arthritic it's easier to screw that 90 deg hose end to the firewall than the other end to the fitting on the engine. LOL
