Old 03-10-2013, 10:54 PM   #1
Tom Turner
Default Re: C3 corvette solid rear NHRA leaga questions
Contact Alf Wiebe. If he will make trailing arms and spring seats for you THAT is the way to go. He built my C-3 (Fred) complete but the trailing arms and the spring setup is the tricky part.
Tom Turner is offline   Reply With Quote
Old 03-11-2013, 05:46 AM   #2
jmcarter
jmcarter's Avatar
Liked 3,221 Times in 980 Posts
Don't know where you live but Jimmy Parker has set up a lot of fast vettes down here in the south. He's on the forum.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-11-2013, 09:59 AM   #3
tj310
If your not running stock why do you care about their rules ? If your running with a different group I'd get in touch with them directly , try to get them to put it on paper, or did they tell you whatever ?HRA allows ?
It's my understanding you have to use a transverse rear leaf spring . No heim joints on the lower arms and your supposed to use the stock frame mounting points. When you make your new control arms they have to be "accepted"
---Trevor
Old 03-11-2013, 11:31 AM   #4
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Alf dose not make trailing arms for corvette anymore, I got the last set.
Bob Pagano A/SA
