Liked 333 Times in 180 Posts
I find it rather hard to believe that there are spiders infesting the timing lights!! However if that is the case then NHRA needs to check daily as part of the pre race maintainence to make sure that there are/is no " obstructions" interfering with the photocells--- and especially for the final rounds!!!!--This is the 3rd time in 3 races that something like this has happened--once at Pomona and twice at G'ville that I heard of!!!
What happened in the Comp final had nothing to do with spiders or snakes.
Had a big spider in one of the photocells at the starting line at Houston. It was causing some bogus ETs and 60's. first I had heard of it.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 03-18-2013 at 08:45 PM. |
Steve I was hoping you would chime in on what happened in the comp final, did Ambrose roll the beams? I was really hoping it wasn't a repeat of what happened in Pomona SS final.
Liked 13 Times in 9 Posts
Not a repeat. There's video on espn360.com, and you can very clearly see Ambrose move backwards out of the beam. It's at around 5:24:15. I wish it was on YouTube so you could step through the video and confirm that the red light doesn't display prior to the stage light going out, as happened with the Super Stock incident.
Here is the deal. If I understood what he told me correctly on the phone, was that he staged very shallow. Stage light flickered. Something not real common with LED lights. He let off the brake and moved in a touch deeper. Problem is that once the brake is released, the shift timer is activated. The timer shifted the trans into 2nd. There is not enough time to pull it back into low, get back on the brake and reset the timer before it is time to go. This explains the small movement. Stuff happens. No conspiracy theories here. Better to be the last round runner up than to be the first round runner up. I didn't really want to explain this as he felt pretty bad. He has won 9 of these things, so he knows how to get it done. Regardless of the outcome, Steve and Bob are my heroes. The 10th will have to wait a little bit.
Liked 2 Times in 1 Post
I was shooting from Aragona's side and it's very difficult to see through the camera, especially with a wide angle, but it appeared to me that Steve was moving backwards when the tree came down.
Dave Kommel |
