Old 03-29-2013, 06:57 PM   #7
treessavoy
Liked 4 Times in 4 Posts
Default Re: Frame Connectors
Originally Posted by Dana Fitzpatrick View Post
JR, last year I had MPR put a cage and tie the frames in a 68 Camaro that had just had a rotisserie resto done on it. Mike closed off the rear of the front sub frames by welding on a plate and ran the same size round moly tubing that he built the cage with,off the plate back to the rear sub frame. The bars run an inch or so beneath the stock floorboards and curve up to the bottom of the rear frame.He then tied these to the main hoop. Welded, but easy to undo, if someone wanted to do so. This way might be an option on your year Camaro,also.,
This is how Dvorak did all his cars. Weld a plate on the ends of the sub frames and connect with round tubing welded only to the sub frames, not to the floor.
JimR
Jim Rountree
